Help bmw key stuck!!!!!
Old Aug 13, 2009 | 07:04 PM
YOREVOL's Avatar
YOREVOL
YOREVOL
Default Help bmw key stuck!!!!!
THE KEY IS STUCK IN THE IGNITION BARREL OF MY MUMS E39 523 BMW ANY IDEAS?
Old Aug 13, 2009 | 07:06 PM
carlo's Avatar
carlo
Is it a automatic it must be in park for the key to release
Old Aug 13, 2009 | 07:08 PM
24vcossiemat's Avatar
24vcossiemat
no more Granada's for me
if it ain't an auto then the barrel is probably buggered, i had this on my old pajero. what i faff.
Old Aug 13, 2009 | 07:11 PM
Mike C's Avatar
Mike C
The Special One
Is it an auto? Common fault on E39's.
Usual cause is the cable, number 11 in this link
http://www.realoem.com/bmw/showparts...03&hg=32&fg=30
YOREVOL's Avatar
YOREVOL
YOREVOL
Yes its an auto and yes its in park but apparently sometimes difficult to get out of park.
I borrowed it today and i cant give it back like this.
Old Aug 13, 2009 | 07:12 PM
Mike C's Avatar
Mike C
The Special One
99.9% definitely that cable above that's gone then. It runs from the ignition barrel to the gear selector
EDIT: It's illustrated in that link, but I chose manual when looking for the model, so it's not in the key. Go back and choose auto and it'll appear.
Old Aug 13, 2009 | 07:13 PM
YOREVOL's Avatar
YOREVOL
YOREVOL
Does the cable adjust as i need a quick fix
Old Aug 13, 2009 | 07:16 PM
24vcossiemat
this suprises me I thought the cable just stops you taking it out of park when the key is not in the ignition. I live and learn. could it be the cable just needs adjusting if you can do this, he says it has been getting hard to get it out of park??? or is it brand new cable time. COULD HE NOT JUST REMOVE THE PLASTIC PANEL UNDER THE BARREL AND PULL THE CABLE TO TRY AND GET THE KEY OUT AS A QUICK FIX FOR TONIGHT???
Old Aug 13, 2009 | 07:19 PM
Mike C's Avatar
Mike C
The Special One
Yes, do as he says, remove the lower plastic trim and have a fiddle, you probably will get it to work, but leave that trim off until it's permanently fixed.
Old Aug 14, 2009 | 12:09 PM
24vcossiemat
did it work I wonder??? let us know mate
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
Oranoco
12
Oct 2, 2015 02:18 PM
muz
Sep 30, 2015 08:29 AM
stevecfrst1
Sep 30, 2015 05:18 AM
