RS2K problems
Old Aug 9, 2009 | 05:18 PM
Rs(555)'s Avatar
Rs(555)
Default RS2K problems
as above i have a j reg rs 2000 track car and last track day it started pulling badly to left and right when i boot it or go slow ........ive changed the bottom arms and wheel bearings......still the same i was thinking maybe engine or gearbox mount but it really is bad when the car is on axle stands and i release clutch there sounds like a loud banging coming from gearbox area,could it be diff in box or a shaft ?????? i know it needs box removing to kow for sure ,but just wondering if anyone else has had the same problems..........cheers jeff
Old Aug 9, 2009 | 06:12 PM
Icurus's Avatar
Icurus
I have a mk5 RS2k track car too
A worn engine mount can make the car veer, a quick check can be done by trying to rock the engine back and forth by grasping the cam cover. The usual mount to go is the one located just below the brake servo.
As too the clutch related problem, prop best to remove the box and inspect if the engine mounts are ok.
Old Aug 9, 2009 | 06:16 PM
Rs(555)'s Avatar
Rs(555)
As too the clutch related problem, prop best to remove the box and inspect.
cheers i dont think the mounts are great but think its the box as its horrific to drive slow or fast its done lots of track days some on slicks ,it was richrs2k old car? i ve had a bit done on it since bought it off him? dont know if you have seen it before..cheers jeff
Old Aug 9, 2009 | 06:23 PM
Icurus's Avatar
Icurus
I remember richrs2k and think I've seen the car, thou cannot be sure!
The MTX-75 box is pretty strong, but not industructable! So might be wise to remove it and give it a good inspection
As you have suspected the usual cause of the car veering left and right on the throttle is the lower arms, but since you have replaced these it has to be engine mounts or the gearbox itself. The inner CV joints, also known as tripods, can wear and are quite expensive from Fords, so a quick solution is to swap them over as they wear in 1 direction by swapping them you are then wearing them in a fresh direction
Old Aug 9, 2009 | 06:57 PM
Rs(555)'s Avatar
Rs(555)
thanks for your helpwill get box out and see what i find
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
