wot size wheels on 50mm drop
hi guys
my s2 rst is on koni adjustables lowerred bout 50mm currently on 15"tsw stealths (yes stealths) hahaha.
fancied 16" mondeo zetec rims, wud they fit wivout any mods?
chris
chris
Shouldn't be too much of a problem, but I would personally not run anything lower than 30mm, as the handling just deteriarates imo. I run 17"s dropped 25mm (although sits lower it seems ) with no arch mods and it used to catch on on side with 2 people in the car, got round that by fitting spring assistors and jobs a goodun
i thought that i brought it like that u see, the buy sed its 50mm drop. cud be rong i guess. but it is well low whichi aint really to happy about. ill get a pic of it on the side
mine is sitting on 17 x 7.5s with 205/40s with 40mm
drop onj koni adjustables, all 4 arches have been ground down
and i still scrape even when im on my own on back if i hit a
bump or manhole cover at speed, its really pissing me of so
atandard wheels may be going back on or swap springs for 25mm
ones but i like it as it is.
im open to suggestions.
Originally Posted by adamS2RST
That looks pretty low mate, just to give you an idea here is mine on 17's 25mm drop on PI stuff
Why anyone would want to lower an RST any more than 25-30mm is beyond me. OK, so they do look good slammed, but they are shite to drive. Also, unless you have special dampers that are designed to take that kind of lowering, they will bottom out and eventually leak.
Also, 7.5x17" wheels are too big. I used to have 7x17" ET35 and thats the limit as far as I would suggest. Even with those wheels and 30mm lowered, it used to hit the arches too often for me.
Originally Posted by tonyturbo
18's and lowered 70mm at front, 60mm at back. rubs occasionally and handles like shit!!!!!!!!!!!!!!!!!!!!!!!
60 mm lowering springs. the front struts have been modified where they go into the hub so as they now sit 10mm proud of the underside of the hub. still has clearance at cv boot. might not be to everyone's liking but it does work. couldnt justify the price of coilovers when i was doing the suspension.
truly stunning car mate. looks lower than mine. i might change suspension to summit of better quality. just using g-max just now to keep it mobile but not really stiff enough. would like coil overs but dont think u get them for the back. could make them i suppose.!!does your wheels rub anywhere? mine rub on arch where it meets bumper. cant trim anymore as nothing left to trim!!!!!!!!!!!!!!!!!!!!
JoeyBoyden
04-01-2024 03:36 PM
JK12
33
26-04-2021 01:09 PM
