who,s got A.L.S& LAUNCH CONTROL(FAO STU @MSD)
AS ABOVE & how much boost do you generate while using it
my a l s makes minus 4--6 psi .launch makes 4---6 psi positive just curious
PassionFords Creator
Hi Andy,
To increase the plenum pressure off throttle with ALS active you will need to run a larger bypass valve. Launch Control is only limited by ignition system, is yours on standard type ignition?
heres the plenum with for now 1 iscv valve
I will take mine for a drive somepoint this week after i have sorted my shocks.
Pretty sure neither of mine make positive boost though.
Im on Dizzy , std cams, T4 and 83 blacks, 7.3:1
Yes still got the gleeb box, bit of a pig when pulling off but does it's job well!!
Had the car nearly 2years, haven't touched the beam bushes when did you see it last.The car seem,s fine now its running as it should ,theres so much power going thought the back wheels it needs a uprated beam which is £1500 from sheady at M.A.D & will be done soon.
Its got very long gears 1st is 75mph 2nd is over 100.
Thats the richy we done a deal with for my dads 3door that he had for 13years.It wasn't on full power when we got it & a few other things needed going, but it is on fooking full power now!!! The launch control is mental!
RWD mate, and I never use the LC cos it just spins like fuck
The ALS is good fun tho, makes sliding about interesting as you feather the throttle the pops and bangs are immense. Obviously I dont do that kind of thing, being the mature adult I am
hi stu what is launch clamp i do not know what my rpm is as i run an spa rev counter ,it drops to zero more or less straight away id guess at 4000 to 4,500 rpm .my als is a bit wimpy it bearly pops let alone bangs sounds crap compared to my mate jason 3dr.which is loud as fook .if i fit the activation switch to my clutch can i use it as full throttle gear change .thanks andy
