The Aerodynamics Thread
OK then,
We all know that as soon you move, you are figthing against air resistance, basically speaking, right?
But at lower speeds, it's far less noticable than at higher speeds.
I think it would be fair to say that, although it will still have a great effect, more powerful vehicles won't be so badly affected by it until they reach a greater speed than those not so powerful.
So, on a 0-60 dash, how big a role could aerodynamics possibly play? Without looking up drag co-efficients, I could name plenty of cars that look comparatively like house bricks which can hit 60 as quick as you like. Could these 0-60 times be improved by fitting splitters, diffusers, canards, vortex generators and all that, or would it be so un-noticable it wouldn't be worth it?
What about 0-100 or the quarter mile?
Or is it only at high speeds, and you'd only notice a major difference on, say, a 0-150 sprint.
And what about handling characteristics?
These aren't specific questions as such, just a general topic of discussion!
![](https://passionford.com/forum/images/smilies/roi.gif)
B1mbo
when we were going for good 0-60, 0-100, quater mile
we took the big spoiler off, i think the wrc spoiler of an escos is working at just under 60mhp ish
i had the steam cleaner on the escos the other day (not accurate i know) but i shot the hot water over the roof and down onto the spoiler, the water seriosly shot off the back lifting the water up !
i thought wow, just like how air would react ! i guess lol
on the 0-150 dash the escos did id did circa 15seconds iirc, rod said it could be down in the 13's with the spoiler off so around a second ssaving iirc !
formerly beefy-rst-2
then you can factor in the other 1 second you would of saved by not being sat in the passenger seat fatty
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
love yoouuu
beef
9500RPM torqueless wonder
Just look at most of the time attack evo all running voltex front bumpers, flat floors and rear diffusers Not got a picture of the full under side but you get the idea from the below, Jspeed are now also doing an off the shelf flat floor for evos for about 500 quid,
![](http://img.photobucket.com/albums/v205/wee-homer/motors%20ect/voltex_aero_bulletproof_automotive.jpg)
Yeah I would imagine the amount of down force the voltex or varis set up for evos would have a massive effect on acceleration especially over 100 but at the same time a flat floor rear diffuser combo when applied properly would help the air under the car move through quicker with less turbulence meaning quicker acceleration due to less drag, but also if the air on the underside is moving quicker than the air over the top then it will also be creating down force so slowing the car down but that is when my eyes start going squint trying to figure aerodynamics out
Patronus
Working on the theory, that one of the performance cars - is either a Merc or Porsche - has a self adjusting spoiler that lifts at above 70mph, i would say that is when aerodynamics comes into play ?
But then at the same time - to counter my own comment, it could literally be, that the shape of said vehicle means that anything over 70 would require some downforce.
i'll shut up and go over there
![LOL](https://passionford.com/forum/images/smilies/icon_lol.gif)
Happily retired
I agree, XSport want to do mods like those shown above on mine, but without highspeed testing who knows if it works, I remember that Merc at Lemans taking off, it scares me. Best left alone.
Testing the future
it's quite simple to grasp how much resistance the air has. if an average family car is using practically all of it's 100 bhp to do about 100 mph, it doesn't take a lot of calculation to tell you that it needs about 12.5 bhp to do 50 mph. so if you could eliminate all wind resistance at 50 mph, you would gain the same acceleration as having an extra 12.5 bhp which is quite significant in a 1.6 mondeo, but not so significant in harvey's escort or rod's sierra.
addressing another point in the thread, changing downforce does not necessarily change drag in the same way.
having said that, 'spoilers' that pop up at speed are mostly to reduce rear lift rather than decrease drag, and they probably usually increase drag.
*** Sierra RS Custard ***
Broadly speaking I beleive that wind resistance is generally accepted as being related to the speed cubed.
So by 200mph, even a very aerodynamic car will be starting to lose a lot of power and at 10mph even a very unaerodynamic car will have no problems.
Where between those 10 and 200 points you are has as much to do with power as aerodynamics, with a car like Rod's for example, it has so much power that even with bad aerodynamics and doing 100mph, those aerodynamic effects have little effect on its ability to still accelerate as it has such a large amount of power that even if it takes 70bhp (my guess not an actual figure) to maintain his speed its still a drop in the ocean but at 200mph and 560bhp to maintain the speed it is really starting to take its toll.
Patronus
so working on the above theories and using Rod's car as an example, if he were doing 200mph with the wind BEHIND him, no cross wind etc, his car would theoretically not need the same amount of bhp to do the same speed ? Although it's doubtfull that the wind would be doing similar speed, the air infront of the car would already be in a state of turbulance when he went through it allowing the car to pass through it with less drag ?
well in terms of wind direction, say your doing 200mph with a 50mph tailwind you will only need enough power to reach 150mph i would imagine, but then saying that it would have to make sense that if there was a 200mph tail wind it would require no power(or maybe a couple of hp) to do 200mph which doesnt seem right to me.
Maybe then the aerodynamics of the rear of the car affects that, ie it being a brick shape at the back and it being able to channel all avaliable air onto the back, like this
![](https://img505.imageshack.us/img505/4691/rearair.jpg)
but since no car is like that the effects wont be as strong, as to be fair your never really gonna be in an environment where you rely primarily on tailwind for your speed
it all depends on what you want the vehicle for, 99% of all aerodynamic aids are to gain downforce for either high speed stability or cornering, by using the air to push onto the car you will be creating drag hence you will be unable to achieve your ultimate top speed.
on tracks you may find all the parts that give you drag may actually give you a higher top speed, this might be down to the dramatic increase in cornering speed that means as you enter the straight you are already at a higher speed than a stock body car.
ermm im a bit drunk and im waffling but i really enjoy these type of threads so lets keep going
Carbon Crazy
mmmm i might have to get my fluid dynamics books out from my aero engineering year at uni!!!
Such aerodynamic tweeks are not something you can home bodge unless you know what you are doing and can do the maths.
Wind tunnels are FAARRRRR easier. But far more expensive.
You can play around with scale models and that would be more than good enough for the cars here. Even homemade slow speed tunnels with smoke streams are adequate for seeing the air flow, turbulent areas, where air flow splits etc etc.
Happily retired
It would be good if a 50mph tailwind meant that you only needed enough Power to reach 150 to hit the double ton, if you errected a sail that may be the case
There is no one formula because it depends on a huge number of factors, not the least of which would be the coefficient of drag on your vehicle from back to front (since it was a tailwind).
Once ran with a heavy tailwind at Brunters & the car was perhaps 1 to 2mph faster under those conditions, dont tell Mike or he will dismiss what turned out to be a record run (183.2mph).
Testing the future
07-10-2015 12:56 PM
DavidK
27-09-2015 02:55 PM
