Beemer
Old Aug 1, 2009 | 01:42 PM
BDBCOS's Avatar
BDBCOS
Unhappy Beemer
My son spoke to me earlier today regarding problems with his 2.0 oil burner turbo bmw. As he was driving, he heard a loud pop, and the car lost most of its power. He says it will not exceed 40mph and is totally gutless.It is also throwing out clouds of black smoke. The obvious thought was that the turbo had let go, but surely the car should run at higher speeds with lack of acceleration, unless the ECU has the ability to limit the speed until the fault is cured. Any ideas?.
Old Aug 1, 2009 | 01:44 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
boost hose blown off, burst intercooler
Old Aug 1, 2009 | 01:46 PM
RichieST's Avatar
RichieST
Clouds of black smoke indicates a rich mixture, or in other words its leaking air somewhere.
As James says, check for a split/loose hose, or the intercooler could possibly have let go.
Old Aug 1, 2009 | 01:49 PM
Rhys's Avatar
Rhys
Turbo knackered likley as they are common on 320d's
Old Aug 1, 2009 | 01:52 PM
1098's Avatar
1098
FIESTAHH
Once you've got it fixed, he can lower his chances of it happening again by investing in a Mercedes xD
Old Aug 1, 2009 | 01:55 PM
RichieST's Avatar
RichieST
Then have the joys of it falling apart around him due to their shocking build quality of late
Old Aug 1, 2009 | 02:13 PM
Mike C's Avatar
Mike C
The Special One
Are you on drugs?
I know soooo many people with new Mercedes, and they're at the dealers more than they're on the road.
Mercedes have to be THE worst built cars on the road
Old Aug 1, 2009 | 02:14 PM
1098's Avatar
1098
FIESTAHH
Lol, some models are more prone to rust like the W210 E55 but they don't fall apart
Mercedes Build Quality > BMW Build Quality > Ford Build Quality
Old Aug 1, 2009 | 02:18 PM
Mike C's Avatar
Mike C
The Special One
They fucking do! After 3 months, The brake discs are warped and the dash is falling to bits, and after another 2 months the discs are warped AGAIN, and 3 of the alloy wheels have corroded!
Hyundai Build Quality > Fiat Build Quality > Perodua Built Quality > 3 year old playing with Lego build quality > Mercedes Build Quality
Old Aug 1, 2009 | 02:36 PM
1098's Avatar
1098
FIESTAHH
Old Aug 1, 2009 | 03:03 PM
RichieST's Avatar
RichieST
The lego cars I used to build were fooking bullet proof
Old Aug 1, 2009 | 07:58 PM
BDBCOS's Avatar
BDBCOS
Thanks for your thoughts guys. Hoses look to be a good starting point.
Old Aug 1, 2009 | 09:56 PM
RichieST's Avatar
RichieST
If the fault isn't obvious then it could be worth taking the hoses off to check them properly, even the tiniest hole/split can cause the symptoms you have described!
Old Aug 3, 2009 | 10:32 AM
BDBCOS's Avatar
BDBCOS
Smile beemer
Thanks again guys. My son has just called me, the hose from turbo to intercooler cracked and split in several places. New part on order.
Old Aug 3, 2009 | 10:36 AM
Mk1-stu's Avatar
Mk1-stu
Patronus
i am actually crying i laughed that much, you fuckin looney
Old Aug 3, 2009 | 10:40 AM
liammcl's Avatar
liammcl
This doesn't explain the smoke but I know they are prone to splitting the plastic inlet manifold, with a loud pop/crack when it happens.
Old Aug 3, 2009 | 11:28 AM
AlexF's Avatar
AlexF
erm it does explain the smoke...
less air with the same fuel = black smoke (unburnt fuel)
alanfordtw-15
20
Aug 1, 2007 03:47 PM
AndyBrew
15
Jan 12, 2007 05:16 PM
Stu @ M Developments
13
Sep 29, 2006 07:37 PM
Kam B
17
Jul 14, 2006 07:35 PM
foreigneRS
May 1, 2006 10:55 PM
