not a ford but a 205 gti
anyone on here any good with these, i run one in the autocross but the fooking thing will not start when its cold unless i give it a bit easy start, once started it will restart fine all day and it goes like stink, i have tried all the obvious things but still refuses to start cold, any ideas ?
Have a look/search through posts on the 205 forum - i've used that site since i bought mine last year & there is loads of info on there
Have a search for posts relating to SAD / Supplementary Air Device as these are quite prone to sticking so when you try to start the car from cold it wont turn over unless you rev the car.
Cleaning the sad and/or throttle body seems to cure the problem in a lot of cases
http://forum.205gtidrivers.com/
Have you changed the leads recently? Just a thought but i had a similar problem with my old GTI for a while, changed the leads and it never happened again.
JoeyBoyden
04-01-2024 02:36 PM
borboyous
22-08-2015 11:17 AM
mrice0107
21-08-2015 07:55 PM
