vw tdi fault 00575 Intake manifold pressure sensor
anyone help?? what and were is this? i presume its not what looks like the charge temp sensor thats at top of engine along the big plastic instake hose from the cooler?
MAP SENSOR - dont know where it is though !
Should be a pipe off the intake manifold connected to a small box mounted off the
engine somewhere. (usually has 3 wires connected to it)
if it is that sensor in the main plastic intake pipe (huge one) make sure you get the right one or take your old one with you .There are three different ones and theres a modified plastic intake pipe as well
scott
scott
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
wheelwizardrefurbs
24-09-2015 08:35 PM
Si B
12-09-2015 06:49 AM
00575, 00575intake, code, fault, hose, intake, intakemanifold, intermittent, manifold, map, pressure, senser, tdi, vw, wwweil132com
