SORTED - Cossie dash car warning diagram (lights flashing?)
The display above the stereo beside the clock where it shows doors/lights/etc....
The rear doors and red low temperature light is flashing, never seen this before???? what's causing it?
First thing I would do is check all the connections into the back of the display module - they can be prone to working loose so make sure they are all tight
Easy fix last night for this, the connector in the door for the warning display wasn't plugged in
It was tucked down inside each rear door so once i found the plug i connected it and it works as it should. I haven't looked at the red temp sensor yet but i suspect that it's basically the same issue.
****NOTE***** Ont the 2wd there are 2 wires for the warning display sensor in the loom going to the door, but on the 4x4 doors there are 3 wires that the other end of the plug connects to. The connector just plugs straight in and it works so I don't know what the 3rd wire is for, but it works without it being connected.
Karl 3dr
102
14-10-2016 08:17 PM
kosienutter
31
22-08-2015 09:55 AM
