Procedure for starting a ............
series one engine thats been stood for 8 years?
What parts would you change ?
What would you do in order ?
Bear in mind thats its had a new petrol tank,fuel filter.water hoses and boost hoses.
Anything else that would be nessassary for bedding it in when running .
any help/info would be greatly appricated
id change the oil and put fresh petrol in (if theres been petrol in it for 8 years that is)
and maybe the minor service items, airfilter sprak plugs leads, or maybe thats a bit over the top!?
as above with fresh oil. filter and fuel.
Bit would turn it over by hand of the crank pully, then after a few turn, I would most likely tunr it over without the plugs in to pump some oil over without to much pressure.
The give it a gentle run out and after a few hundred miles change the oil and fuilds.
DixieTheKid
11
06-06-2020 11:20 AM
TPM961
15-01-2018 10:50 AM
