removing cossie head..
Old 14-12-2004 | 06:56 PM
Switch's Avatar
Switch
Default removing cossie head..
that seems fine. my problem is that when i am putting it back on, i am gonna use a set of old head bolts to guide it on but i think the downpipe is in the way of the 2wd exhaust manifold. anyone experienced this? or can i get away with short guide bolts and slip the manifold back under the down pipe then onto the bolts?
thanks any imput would be helpful, i am trying to avoid removeing downpipe.
Old 14-12-2004 | 07:06 PM
SteveB's Avatar
SteveB
Mine are about 30-40mm long
Old 14-12-2004 | 07:08 PM
Switch's Avatar
Switch
thats in total steve? or just whats exposed when screwed into block?
Old 14-12-2004 | 07:10 PM
B11GNS's Avatar
B11GNS
It is difficult but possible, you just need to get exhaust as far out the way as possible, you should just be able to get it back far enough if you unhook it from the hangers underneith and lower the roll bar
SteveB's Avatar
SteveB
total
Old 14-12-2004 | 07:14 PM
Switch's Avatar
Switch
that should be fine then steve I reckon I got 30-40 mm cleanance with the downpipe tied back and to the side. how do ya get the bolts back out of the head? as they are soo short? I will cut grooves to unscrew them, then do ya just use a set of long nose pliers?
B11GNS's Avatar
B11GNS
How do you then get them out once the head is on?
Old 14-12-2004 | 07:24 PM
Switch's Avatar
Switch
as said mate, I think they are grooved for a srcew driver then once loose they use a pair of long nose pliers
Old 14-12-2004 | 07:32 PM
SteveB's Avatar
SteveB
Slotted and then a long screw driver
Old 14-12-2004 | 07:57 PM
foreigneRS's Avatar
foreigneRS
Testing the future
long nose pliers are shit, you want a magnet on a stick
personally, i remove the downpipe. it's an easy job and just require 4 bolts to be undone. it's all stainless anyway, and the exhaust is flanged together rather than the big tube clamped over smaller tube method.
Old 14-12-2004 | 08:27 PM
Gaaables's Avatar
Gaaables
i only cut th head off the bolts and still managed to get my head back on, just had a mate holding the exhaust rite back and went on with no real problems
Old 14-12-2004 | 08:29 PM
Switch's Avatar
Switch
will try the screwdriver route first
Old 14-12-2004 | 08:37 PM
CraigN's Avatar
CraigN
why not remove downpipe is your exhaust welded together or sommit ? it just pulls out thru the engine bay
Old 14-12-2004 | 08:56 PM
Switch's Avatar
Switch
Cause last time i took it off, it was a fooker to get back on.
Fudgey
17-09-2015 01:06 PM
Si B
12-09-2015 06:49 AM
grishenko45
09-09-2015 12:58 PM
hopper350
04-09-2015 12:53 AM
Quick Reply: removing cossie head..
