running in clutches????
as in title.
every1 has different views.
got an escort s2 and 2day had fitted
paddle plate, with standard cover.
should i be easy for a few miles and try run it in
or?????? (how many miles)
i dont understand. had it all fitted by decsent company that builds race cars etc.
but i can fucking hear the release bearing, WELL IT SOUNDS LIKE IT.
it rattles on idile then when clutch is pressed it goes away!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
this is the norm with paddle clutches, and i have seen them shatter because the flywheel was'nt skimmed
#1 in Spelling Club
Cerametallic clutch material is SO much harder than normal clutch material, it simply doesn't wear anywhere near as quickly (unless the clutch is slipping, which obviously isn't good).
Now imagine the cross-section of a worn flywheel (just like a worn brake disc), with high spots. The clutch only contacts these high spots until it wears to follow the mirror-image of the flywheel. However, the Cerametallic material takes AGES to do this and in the meantime, it might only be contacting 10-20% of the flywheel, so never really grips properly from the word go.
Live long and prosper!!
No, 50% that know whats right do it and 50% that want to save £50/can't be bothered don't.
do it once do it properly
Paul
