Escort or Sierra Fuel Level Resistance?
On the 200 scale it will not read anything really just flashes a number then you get a 1 on the left of the screen.
Christian
I can post the sender to you if you want so you can test it yourself or whatever, its just what was in a tank i bought ages ago and im on a dip tube type now in the pro alloy tank so have no need for it.
Pm me your address if you want it.
Christian
When I tested mine, it showed 62 ohms and I think the tank is almost empty.
I did have a strange occurrence with it last time I filled it though, the car appeared to have run out of fuel, but when I took it to the petrol station, it only took £25. So, really not sure.
That said, since putting that £25 in, I've done at least 100 miles, so there can't be much in it.
Gav, I agree, from your results it does look like 200-300ohms although this means that my reading makes no sense whatsoever!!![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Are the Cossie and RST senders the same I wonder.
