General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Depending on what valve you want to use, could make one, or to fit an easier to use iscv use a omega etc one, where it has simply just a 1/2" pipe either side to attach as you like anywhere then.
I'm sure some alfa's had the other end to fit a cossie one into, the ones with the pipe connections at 90 degrees to each other, similar to the omega one
