Help please erst stalling probs.
Old Jun 6, 2009 | 01:45 PM
jamieRST's Avatar
jamieRST
Default Help please erst stalling probs.
Hi guys,
having a minor problem with my rs,it stalls randomly,and if i rev it with a bit of grunt and let go, when it drops to 1k it just cuts out.
been told it could be a vacuum problem? or blocked breathers?
was thinking of getting a piperx crankcase breather also.
the elbow coming of the left side of the rocker cover is also a bit of a weird shape.could it be this causing the problem?
any help/advice much appreciated
jamie
https://passionford.com/forum/restor...2-project.html
Old Jun 6, 2009 | 01:46 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
breather hoses split, or the wrong type dump valve are common
Old Jun 6, 2009 | 01:57 PM
I was gonna say the same as the above.The mfi engines need a good vacumn or they will just keep cutting out.
Old Jun 6, 2009 | 02:07 PM
jamieRST's Avatar
jamieRST
dont think any pipes are split and my dump valve is a bailey twin piston red one which is fitted properly.
the circled bit in the pic is what i have told is a bit of a funny shape,could this be causing the prob?if so how do i sort it .
cheeRS
jamie
Old Jun 6, 2009 | 02:16 PM
st3v3's Avatar
st3v3
theres also the breather on the other end of the rocker cover, on the right.
This one was more of a problem on all 4 of my cvh engines.
Old Jun 6, 2009 | 02:18 PM
Well if it doesnt look right ie if its kinked it might be causing the fault.Do you have any better pics of that pipe.
Old Jun 6, 2009 | 02:23 PM
jamieRST's Avatar
jamieRST
sorry not got another pic of the pipe and the cars in the garage 15 mins up the road .
its sort of kinked in the middle,any ideas where i could get a replacement from?or another scrapyard jobby
Old Jun 6, 2009 | 02:32 PM
Chopshop85's Avatar
Chopshop85
I always thought they had these little pot thingys (techincal i know!)
However Mine has just started doing the same thing and after an hour of checking every vacuum pipe twice, dip stick etc etc, it tunrt out to be a tiny split in the bottom brake servo! Which was obviously sucking in a bit of extra air, enough to make it stall.
Old Jun 6, 2009 | 02:35 PM
nickscunny's Avatar
nickscunny
Originally Posted by Chopshop85
I always thought they had these little pot thingys (techincal i know!)]
Your an absolute genious!!!
I been suffering from same symptoms, tried everything and Im pulling my hair out and come to think of it a strange hissing noise is coming from my servo!!!
Old Jun 6, 2009 | 02:40 PM
Chopshop85's Avatar
Chopshop85
Take the litle black pipe off that comes from the servo into the inlet plenum. and stick a finger in the hole in the plenum, then start the car, should run then. ( not very well obviously )
Old Jun 6, 2009 | 02:41 PM
Sometimes the diaphram in the dump valves leak too.
Old Jun 6, 2009 | 02:55 PM
jamieRST's Avatar
jamieRST
right well,i do not have the same as what chop shop has and after researching on the bay,ive looked at another 4 rs with it.its the crankcase breather,wondered why when i looked in my haynes at it and looked on my car i couldnt find it,obviously as it doesnt exist,just like i didnt have a thermostat,pikey bastard who sold it to me
Mc5506
Oct 5, 2015 09:57 PM
beller
Sep 21, 2015 04:13 AM
jay030787
Sep 18, 2015 04:38 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
