dump valve help
Old Dec 8, 2004 | 10:52 PM
zaki's Avatar
zaki
Default dump valve help
I have a s1 rs turbo which came with a diaphram dump valve, i changed it to a bailey twin piston. and 4 some reason on idle it kept cuting out, when i changed it back it was fine. any ideas why it was doing this.
TIFF's Avatar
TIFF
Chasing Radders
Bin it, there shit
Old Dec 8, 2004 | 10:57 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
see above
Old Dec 8, 2004 | 10:59 PM
Alvyn's Avatar
Alvyn
Default Re: dump valve help
R u sure it's a twin piston type DV26(I believe) as it sounds that it's a DV24.. which do affect the idle on cars running fuel metering units,failing that diaphram could be split or do as above also
Old Dec 8, 2004 | 11:20 PM
zaki's Avatar
zaki
im not sure if it was a twin piston one but the reason i was changing it was becuase the diapham one doesnt make a sound, are diapham one really shit then?
Old Dec 8, 2004 | 11:27 PM
Alvyn's Avatar
Alvyn
easy way to check on the Bailey is to take it off and look inside the bottom DV26 ones for the Rs turbo have a piston in the middle the other one DONT and will not idle on rst's
Old Dec 8, 2004 | 11:32 PM
TIFF's Avatar
TIFF
Chasing Radders
Take it off totally and your car will be alot better to drive
Old Dec 8, 2004 | 11:33 PM
vroooom ptssssh
It Wasnt Me!
diaphragm one was prob split..... and losing boost.
Old Dec 8, 2004 | 11:34 PM
Alvyn's Avatar
Alvyn
BUT he might like the sound or lack of it
Old Dec 9, 2004 | 05:38 AM
james_birch's Avatar
james_birch
Take ther bus brake sound device off!
you will notice the diff totally! when u drive people wont be making the wanker sign at you when u change gear on boost!
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
