Head gasket, which thickness to go for.... SR20det
hi all.
as the head has to come of for some work i need to change the head gasket.
why would one choose a certain thickness to use over others?
engine in question is SR20DET, if spec is needed to help answer what thickness i should go for just ask
theres a few thickness's, 1.1mm, 1.6mm, 1.9mm, 2.0mm and have no idea what pro's and con's all these sizes have if any.
any help and info would be appriciated
*** Sierra RS Custard ***
hi all.
Thinner = higher compression
Thicker = lower compression
There are some other mild effects, such as squish band changes etc, but they arent likely to effect you in any way that matters.
Ask the person mapping the car what CR they want it to be for the spec of your other parts, and go for the gasket that gives the closest to that.
Or if its a standard engine on an off the shelf chip intended for standard compression, go for the one that gives nearest to standard compression.
So essentially, I cant actually recomend a particular one im afraid and I dont really see how anyone else can without you giving a LOT more information!
thanx for replies lads... except for the skyline one, lol
chip the car is not getting tunes, only the head has to come off to get snapped ex manifold studs drilled out, also one has been cross threaded
failry basic spec, turbo elbow, 3"ex pipe, tubular manifold, boost controller, 1.0bar boost!
but will i not be able to run higher boost with a thicker gasket?
sound like a bit of a chav saying that but would love to be holding over 1 bar of boost, avcr is set to 1.2bar but cant even peak 1bar! probably something else to address in regards to the not holding boost situation.
if you are unsure then use a vernier to measure the one thats come off....
then just order the same, but as its been said if its not going for big power just order a std one.
#1 in Spelling Club
If it's got a Nissan logo, then it's a standard gasket. If it hasn't then it's most probably got a logo of whatever make it is and a part number.
My opinion is still as above, regardless of whats in it now, fit a standard gasket for sub 350bhp.
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
