Target Laser Track 400 Garage Door opener
Spelling Club King!
Traffic cops are wise to it, and it's a case of 'perverting the course of justice' if you're stopped. It makes the Laser give off a wild reading, and doesn't actually stop it from working - so they know they've been 'jammed'.
Or you could be talking about opening your garage door, they're ace at that.
It brings up an error 3 i think on the gun cause ive had a go with a gun and a car fitted with one. This error can be brought up by the slightest movement when using it. It stops it working for 7 seconds then switchs off which is where it makes it kindof legal as it has recognised its not your garage doors its open so it switchs off.
Unlike the old jammers that came up JAM on the gun.
It opens the gates so it works very well
Testing the future
i actually like the look of that for it's intended use. i'm hoping to get planning permission for a garage and it would be brilliant to roll up on the bike and have that open up the door so that i can ride straight in.
to the batcave robin
I heard that they record your number plate if they get that error or think you have jammed it, then if your number comes up again I think they take things further!
I think you'll be ok just using it for the gates/garage door tho
happened me once.pressed the house gates closed but actually opened the garage doors.
rob v
If you converted your manual door to an electric one then the motors hold the door closed. Then when you buy one of these for your car and also you need the other part that would sit somewhere where it can detect the car when you want it to and you wire it into the garage door opener and it will open when you drive up to it.
My friend has it to open his gates and works really well. When guy was out servicing the gates he wired it in for him.
JoeyBoyden
04-01-2024 02:36 PM
mrice0107
21-08-2015 07:55 PM
saph in dorset
14-08-2015 10:10 AM
