do i need my tps sensor connected
Old Dec 1, 2004 | 05:48 PM
dave1982rst's Avatar
dave1982rst
Default do i need my tps sensor connected
as title
my rs turbo was cutting out when driving so i disconnected it and it dont cut out now can anyone help me
Old Dec 1, 2004 | 05:58 PM
Stu @ M Developments's Avatar
PassionFords Creator
If you use boost without it, she may meltdown. Get her fixed
Old Dec 1, 2004 | 05:59 PM
dave1982rst
y would it be cutting out with it connected its doing my head in
Old Dec 1, 2004 | 06:10 PM
Wazzzer's Avatar
Wazzzer
sounds like its fecked mate, just so happens I have a spare one in my shed...
Old Dec 1, 2004 | 06:22 PM
dave1982rst
lol i need it asap an u in the iow
and im in kent lol
how could it be that both of mine r fecked
Old Dec 1, 2004 | 06:39 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
its basically a variable resistor that changes resistance as the throttle opens wider, the ECU needs this information to change the air/fuel mixture jus incase u didnt know
Old Dec 1, 2004 | 06:42 PM
dave1982rst
where can i get a new one then lol that works
Old Dec 1, 2004 | 06:47 PM
ECU Monitor Enthusiast
Sorry, you are technically wrong
(if this RST S1/S2 car is running original KE jetronic system)
The tps on this car is only 2 micro switches. (you can hear them click)
So the fuel ecu, knows when idle or full load is being demanded.
It is NOT a variable resistor type as per cossie ... etc...
Old Dec 1, 2004 | 06:50 PM
dave1982rst
so with it not connected does it mean the fuel ecu thinks its on full load
would the problem be with my fuel ecu cos the problem has got worse over time
vroooom ptssssh
It Wasnt Me!
ok just burst my technical bubble
Old Dec 1, 2004 | 06:51 PM
dave1982rst
lol init good try mate any help here is better than wot i know cos if i knew id be happy lol
Old Dec 1, 2004 | 06:56 PM
With it NOT connected, the FUEL ecu thinks you are in part load.
I.E Not idle and NOT full load.
On most ecu's, extra fuel is only added for high boost conditions when the throttle is fully opened.
Not having this extra enrichment particularly when tuned beyond its original power level,
the tuner may be relying on this enrichment to get the AFR correct so preventing melt down.
I may be wrong but to me, it sounds like you have other issues with the car and it may not be the TPS sensor !!
Old Dec 1, 2004 | 07:01 PM
dave1982rst
im only running 8psi at the mo need a chip but the engine is low comp and stage 3 head and piper 285t2 cam and im running a stage 1 2wd cossie turbo
wot else could it be it was doing it with my mates chipped ecu but not as bad since i had the fueling set up its doing it more
vroooom ptssssh
It Wasnt Me!
i'd get it set up on the RR to be sure then take ti from their!
Old Dec 1, 2004 | 07:02 PM
dave1982rst
ive got it booked in at the tuner near me dartford tunning people round my way have said there good all i want for the mo is for it to run rite then when i get it chipped i will venture up north to the big tuners lol
Old Dec 1, 2004 | 07:04 PM
dave1982rst, If you have changed the engine spec but NOT the fuelling this
could be your problem. Too lean under load !
A chipped ignition ecu (silver box) will NOT adjust the fuelling !
As vroooom ptssssh, says get it checked out/set up properly -
Old Dec 1, 2004 | 07:06 PM
dave1982rst
would that make it cut out tho like it is
its doing it on normal driving not just on full load even pulling away like a grand dad taking my time it still does it
and i reved it on the spot up to 4k and let off the put throttle bk down and nothign till the revs died to 1k then it reved again
so it mite not be the tps sensor fecking up then
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
