Where to find the best stage 1 tune
Old 30-11-2004 | 10:16 AM
churchy's Avatar
churchy
From: Out Shooting Burgelers, cause thats what Norfolk people do!!!
Default Where to find the best stage 1 tune
Good morning, I have a 93 saff 4x4 with 70k showing. it is completley bog standard apart from a stainless mongoose exhaust and a ramair panel filter. The engine and turbo are fine. My question to you good people is where the best place would be to take my pride and joy to for a stage one tune. I'm in Norfolk, so the nearer the better, but not essential. Would 280bhp be asking too much?
Old 30-11-2004 | 10:21 AM
mattbibs's Avatar
mattbibs
karl @ NMS is reknown for his stage 1 tunes! 280hp is easily achieveable!
Old 30-11-2004 | 10:22 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
If you want a generic off the shelf chip, then Harvey at SCS in Peterborough (01733 576 614) is where you should go to have an Ahmed chip fitted.
If you don't mind paying the extra for a live map then Stu (Blackpool), Karl (Coventry) or Ahmed (Romford) will sort you out....
Stu @ M Developments's Avatar
PassionFords Creator
Youve got AP Tuning on your doorstep pal
Old 30-11-2004 | 10:25 AM
Mike Rainbird
Caraholic
That's Gary with the black Evo VII and Christian with the slow white RST , who are agent's for Stu's (MSD) chips .
Old 30-11-2004 | 10:26 AM
CraigN's Avatar
CraigN
stu can u map a car on greys on a l6 without the closed loop stuff ?
sorry for the hijack
Old 30-11-2004 | 10:28 AM
Yes mate, of course we can
churchy's Avatar
churchy
[/quote]
how much extra would a live map cost, and what are the benifits over a generic chip?
Old 30-11-2004 | 10:32 AM
churchy's Avatar
churchy
I'll have to have a word with Gary when I see him tonight, hopefully he'll be there, cheeRS Mike
Old 30-11-2004 | 10:36 AM
Mike Rainbird
Caraholic
A generic chip should be more conservative in it's boost and ignition curve to take into account normal wear and tear etc and all the unknown variables of engine that has been through several owners and is a high meileage.
A live map can push the engine to it's limits, as you are det checking, so can push that little bit harder (to the point of det and then pulling back). Expect to pay around twice as much for a live map as to fitting a generic chip.
Old 30-11-2004 | 10:43 AM
churchy's Avatar
churchy
Sounds a bit painful, so would it be safer for the engine to fit a normal chip? Or is just as safe, just better tuned.
Old 30-11-2004 | 10:46 AM
Be aware that your 93saff has full closed loop capability and its worth taking advantage of it... just to confuse you somemore
Old 30-11-2004 | 10:53 AM
churchy's Avatar
churchy
That sounds pretty sweet, I don't know what a full closed loop capability is, but it sounds cool!, does that mean I'm better off with live mapping? Sorry for my stupidity, I'm an engineer, not a mechanic, and yes, the two are very different.
Old 30-11-2004 | 11:01 AM
churchy,
Its not stupidity pal, far from it, just a different trade so dont appologise for asking questions, thats what teh forums for
Closed loop is a feature late cars have as std that allows the in built sensors to control your fuelling properly and as such allow reasonable economy with very good and very clean everyday running. Traditionally tuners have reverted back to old fashioned mapping techniques to give the YB more power but we have a new range of chips that retain the closed loop feature right the way up to 750CC and 600Bhp+ thats fully compatible with the ecu you have as std. (Feature in Perf Ford coming soon )
For stage 1 to stage 3 we can supply this system off the shelf ourselves or via our dealer network (you have AP Tuning Locally) should you prefer professional fitment and tuning, which i personally strongly recommend because ideally you really need the fuelling at high boost checking, as with all due respect, your fuel system is probably 11+years old now and in unknown condition. Admittedly the system ages very well and its probably more than capable of the increased power hike, but better to have the fuelling and boost checked and verified as safe by a pro.
Hope this helps.
Old 30-11-2004 | 11:08 AM
churchy's Avatar
churchy
Nice one Stu, I appreciate your time. I'll have a word with Gary from AP at the Norfolk meet tonight, sounds like the way I will go. Will 280 be possible this way, it would be nice to have the edge over other stage 1 cossies, and maybe the odd scoobie.
Old 30-11-2004 | 11:12 AM
Yes, i can send Gary a suitable file across for a larger than normal boost level thats been tried and tested on many vehicles.
Alternatively, why not go for dark greens and the same closed loop software? and 320+bhp?
Old 30-11-2004 | 11:18 AM
churchy's Avatar
churchy
Won't I need to start changing stuff like the head gasket, brakes and the like once I'm over the 300+ mark? I'd love to get the maximum out of my car, but I wanna do it safely without cutting corners so I don't blow it up, as I do drive it quite hard.
Old 30-11-2004 | 11:20 AM
Jamz's Avatar
Jamz
No! He'll kill himself, trust me I've seen him drive
Although........
Old 30-11-2004 | 11:23 AM
The head gasket is a debateable point. If its due to fail, it will fail. If its ok, it may last a long time, its all laregly dependant on:
A) Its condition now.
B) The abuse it recieves from you.
A conservative 24peak and 22held on that engine will take all the pain you can give it and still drive exactly as it does now or better with fuel economy and efficiency as it is now or better. In many ways its safer than the stage 1 as its got less duration on the injectors and has teh added bonus that:
A) The injectors are brand new.
B) The map sensor is brand new.
So your improving things as you go along
Brakes are generally fine if in good condition, but again, its all down to your driving style and wether you personally find the brakes are delivering what you ask of them.
Old 30-11-2004 | 11:31 AM
churchy's Avatar
churchy
I see, but will a standard T3 hit that sort of boost? What would the cost of this route be compared to the stg 1 chip/actuator route? I can get some cheap greens off here if this is the best route, it sounds good. Oooooh, I'm starting to dribble! And I might want to kill myself on the road for your info Mr Jamz
Old 30-11-2004 | 11:43 AM
The turbo again is an unknown entity to me personally but as an example, myself and many others have old T3's running this level for fun and still going strong.. its 24+maintained that destroys them as a rule
If you were to buy the kit from me you would be looking at:
Stg 2 Evochip "Closed loop" Software: Ł250
4x greens Ł208
1x 3bar Ł75
1x -31 act Ł65
Delivery Ł8
Total: Ł606
Or Ł565 as a package delivered before 1pm tomorrow.
You will have local fitting and checking on top, or a variation of this price if you buy it all direct from AP Tuning. Gary may even be slightly cheaper, you never know till you try.
Old 30-11-2004 | 11:53 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Mike you cheeky B'Stard!! I'll have to take you for a spin in the new 'refined' version!! (Read - No screamer pipe!!)
Churchy, indeed we can help you out. I'm not sure who you are, but no doubt I will recognise you at the meet!!
Gary and I are hoping to come along, but have LOADS on at the moment, which is involving some evenings!!
I reckon we might make it, even if only to the McD's bit. Speak then!!
Old 30-11-2004 | 12:04 PM
Matt's Avatar
Matt
4x greens Ł208
1x 3bar Ł75
1x -31 act Ł65
Delivery Ł8
Total: Ł606
really cant complain at that at all stu
Old 30-11-2004 | 12:08 PM
churchy's Avatar
churchy
Nice one Christian, jus look for the sexy Ferengi style ears, and the ott voice, you won't miss me mate. (I was the 1 warming my hands off your glowing turbo last month on the maccy d's car park). I don't mind waiting or paying extra if its quality top draw craftsmanship, as u get what u pay for in this world! speak to ya tonight mate.
Old 30-11-2004 | 12:09 PM
Thanks Matt.
Incidentally, if you wish to go for conventional non lambda software, its Ł100 less. Just so you have something to compare to other compaines adverts as no-one else will be charging Ł250 for the chip if its not the new generation Closed loop software. So Ł465 delivered for non Lambda controlled, but i strongly recommed you stick with Lambda control as "Its the future"
Old 30-11-2004 | 12:11 PM
churchy,
Great attitude.. very refreshing to see.
Christian, have him stuffed and replicated, and il take 3
Old 30-11-2004 | 12:16 PM
churchy's Avatar
churchy
Some things are the same in engineering as in mechanics. I've seen what cheap alternatives do for ya, and i'm the poor sod that has to put it right, send mickey mouse back to America!
Old 30-11-2004 | 12:18 PM
danvisteon's Avatar
danvisteon
churchy,
pmsl but very true, sorry to hijack this thread how much for a remap on my M3 and also do you map in the vanos as well or does that do it's own thing based on other sensor variables???
Old 30-11-2004 | 01:03 PM
churchy's Avatar
churchy
Nice 1 son, You've gone and frightened everyone off with ya big grizzley M3. My mates got one of them, he can't handle it for shit - skinny arms.
Old 30-11-2004 | 02:25 PM
Smit's Avatar
Smit
The 60ft Launch King
Churchy - if your about tonight at the norfolk meet i could take you for a drive down the road as i'm attending tonight.
My car is a stage 3 running about 330 and features the conversion Stu has mentioned...
Jamz will tell ya what it's like
Old 30-11-2004 | 02:49 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Churchy. If you take smit up on his offer ffs make sure he has a new pair of glasses with him, else he cant see feck all
Old 30-11-2004 | 03:07 PM
churchy's Avatar
churchy
CheeRS Smit, I think I will take you up on that offer, it'll be nice to compare, though i'll have a million and one questions. See ya tonight mate, and bring ya glasses with ya (not your sunglasses)
Old 30-11-2004 | 03:09 PM
Jamz's Avatar
Jamz
It's but you might want to check your brakes BEFORE trying to stop from 130+ mph
Old 30-11-2004 | 03:13 PM
Smit's Avatar
Smit
Sorry no glasses
Brakes are fine cheers
Old 30-11-2004 | 03:17 PM
churchy's Avatar
churchy
Fuck it, life is for living, top poster by the way, I want 1.
Old 30-11-2004 | 10:31 PM
Adrian's Avatar
Adrian
churchy,
You will change your mind once you've met him..
Old 01-12-2004 | 09:51 AM
So how did the test drive go?
Old 01-12-2004 | 10:19 AM
churchy's Avatar
churchy
Well, I was quite happily talkin away to smit, when all of a sudden he put his foot down all the way up to the redline , let it bounce off the limiter a few times before a gear change , and repeated that all the way to about 155 i think . It shut me up for a few minutes, which is very hard to do . Very impressive to say the least, as to was the braking. It cant be good for the organs to stop that quick!
Old 01-12-2004 | 10:30 AM
Christian and Beccy
#1 in Spelling Club
So, when can we book you in then??
Old 01-12-2004 | 11:22 AM
Quick Reply: Where to find the best stage 1 tune
