rev counter adjustment mk6 running fez tub mgnt
Just got me GTi restarted after the engine build where i replaced the original management with fez turbo OFAB gear,
but... the rev counter seems to be running at 1/2 ie showing 600rpm but idling at more like 1200
ive heard there is a fix for a mfi to cossie jus woindered if the same thing may apply for this application or whether anyone knows better?
cheers in advance
cheers in advance
On the mk4 escorts cb there are a number of different rev counters that fit different types of ignition. The late XR3i's were EFI so I think you just had to use the rev counter from one of them.
Are there any mk6 escorts that use different types of ignition?
gonna have to experiment,
dont think the HCS had rev counters
mite raid mapolins n build meself a transformer to double the signal voltage
nope nope nope
fiesta tbos use wasted spark ignition so you will need a fiesta turbo or as essex boy says a mk4 efi rev counter.
a zetec one wont work if yours isnt working now
JoeyBoyden
18-08-2015 05:56 PM
ekjim
17-08-2015 08:57 PM
cozzy jeff
14-08-2015 05:46 PM
