4x4 saph fuel pump relay location?
Old Mar 8, 2009 | 10:40 AM
stevie.p22's Avatar
stevie.p22
Default 4x4 saph fuel pump relay location?
Just on with trying to re-wire my fuel pump but cant find where the relay is, its not behind glove box like on 2wds, if its located in the fuse box in the engine bay, which relay is it? Tried searching on here for an answer,but no joy. Thanks
Old Mar 8, 2009 | 10:44 AM
xr4x4rs's Avatar
xr4x4rs
its located behind the glovebox ond a 4wd, need to pull the glovebox out and its on the left with the abs and heateed screen relays should be yellow
but if your rewiring the fuel pump theres no need to touch this as you need this relay still
Old Mar 8, 2009 | 10:45 AM
Neil S's Avatar
Neil S
It's behind the dash in the passenger side footwell. If you put your hand up between the transmission tunnel and the dash (i.e. to the left of the ashtray) then you should feel a cluster of about 4 relays.
Access is easiest if you pull the glovebox out, unclip the ECU and unbolt the relay frame (there's 2 11mm nuts from memory). You can then pull the relays down into the footwell.
HTH!
Neil.
Old Mar 8, 2009 | 10:51 AM
stevie.p22's Avatar
stevie.p22
Thanks for the quick replys fellas! I didn't know they were hidded away behind the dash. xr4x4rs, I bought a wiring kit off 'prometheus' off here, and it has a new relay with it, so needed to find where the relays were. Thanks again!
Old Mar 8, 2009 | 07:34 PM
xr4x4rs's Avatar
xr4x4rs
yeah you use both relays
the old relay signals the new relay, well thats how i and many others have done it lol
Old Mar 28, 2009 | 07:23 AM
Neil S's Avatar
Neil S
Must be mushroom season eh?
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
