S2 missfire on boost
Old 27-11-2004, 04:33 PM
Paul
Paul's Avatar
Default S2 missfire on boost
Only recently my S2 has started to missfire onboost at 10psi and above, i've look at the plugs and tehy are fine leadas are newish so is the dizzy, rotor arm and cap. What else could it be?
Old 27-11-2004, 04:57 PM
KSA-Cossie
KSA-Cossie's Avatar
Connection to and or the amal valve.
Old 27-11-2004, 05:02 PM
Paul
Paul's Avatar
connection is fine to that
Old 27-11-2004, 05:06 PM
KSA-Cossie
KSA-Cossie's Avatar
And what about the valve itself?
Old 27-11-2004, 05:11 PM
Paul
Paul's Avatar
dunno lol how can i tell if its playing up ?
Old 27-11-2004, 07:40 PM
Wazzzer
Wazzzer's Avatar
it should click a couple of times when you turn the ignition to the second stage...
Old 27-11-2004, 07:45 PM
apples24
apples24's Avatar
if you need one i have a fully working s2 amal valve
in experiance with boost probs on rsts its been plug and lead related, id also look for leaking hoses, colapsing hoses, timing , co levels etc all basic stuff but never say its a newish set of plugs/leads cant be that
some just give up the ghost so early its unreal
im no expert but every little helps aye
Old 28-11-2004, 09:24 AM
James Raby
James Raby's Avatar
I had misfire on boost recently, cured with new cap and rotor arm...
Got to sort my cold start problems out now ROFL
timsrs
13-11-2018 11:48 AM
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
oilman
Trader Parts for Sale.
23-09-2015 07:32 PM
Quick Reply: S2 missfire on boost
