Help Needed Please
Old Feb 15, 2009 | 05:44 PM
jan's Avatar
jan
Default Help Needed Please
Hi
Could someone help me out please. I have an R reg 1.8SI Escort, and of late it has started to cut out when I stop, it does not do it all the time and starts straight back up with no problem, the thing is when it did it the other night I had slowed down to turn left at the traffic lights, it cut out the only reason I knew was the steering was hard to turn and I nearly hit some bollards.
Could it be the air flow meter? this has been mentioned to me but i have also been told that if it was this then it wouldn't start straight away like it does. I had put injector cleaner in. Can anyone point me in the right direction before I have to spend on all kinds before finding the problem!
Thanks in advance
Jan
Edit/Delete Message
Old Feb 15, 2009 | 05:51 PM
NUTS RuS's Avatar
NUTS RuS
Clean the throttle housing around the butterfly
Old Feb 15, 2009 | 06:23 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Try cleaning the ISCV.
Old Feb 15, 2009 | 07:49 PM
B19 JUB's Avatar
B19 JUB
as i put in another post on here the pcv hose is quite common on these for sucking flat or piercing.try taking idle valve off and clean it.that might help
Old Feb 16, 2009 | 10:41 PM
jan's Avatar
jan
Wink
Thankyou will try, or will get someone to!!!! I will let you know how I go
Old Feb 16, 2009 | 11:03 PM
BM08's Avatar
BM08
When my escort gti had idling problems it turned out to be the throttle position sensor
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
