problem with my lads fiesta turbo
i need some help with a fiesta turbo ,keeps chucking smoke out exhaust ,just had a new turbo ,done the valve stem seals ,breather is all clear , thought it was crank case pressure ,just need some more things to try before the engine comes out and stripped
cheers in advance
jp
cheers in advance
jp
you've mentioned all obvious points. mine was doing the same and afriad it is too much pressure in the crankcase!
does it smoke out of the breather on boost? mine did. advice is to strip it down now before it goes bang like mine did!
Is the hose to the map sensor connected?? Mine pooped off once and I thought I'd fooked the engine because of all the smoke! It was runnin slightly rich!!
The rings and headgasket are gone now tho!
Hope it aint too serious.
Originally Posted by YUM360
Have you checked the oil return pipe????
JoeyBoyden
04-01-2024 02:36 PM
vdun01
Ford Fiesta
05-10-2017 08:14 AM
