ERST chipping and use of bleed valves
Old 29-01-2009 | 05:02 PM
Oranoco's Avatar
Oranoco
Default ERST chipping and use of bleed valves
Having a discussion on another forumn about bleed valves and chipping. A guy is claiming that his RST had a one off chip by Ahmed Bayjoo that cut the boost pressure back once the ACT's were to high from 16psi to 7psi (iirc). And that the use of bleed valves is all wrong and the car should be setup to control boost from the ECU or have a stand alone EBC. He also claimed teh boost level should be chosen and then the car mapped accordingly.
Now I've already pointed out that the Bosch KE-Jetronic system is mechanical and therefor there is nothing to map. But the rest of the comments I would like some back up as to my thoughts before I make a tit out of myself.
1. I wasn't aware the ERST ECU could do such a thing with regards to the boost. I know when the ACT gets too high it knocks back the ignition timing so wouldn't a boost control feature even a crude one require an additional output from the ECU?
2. I'm personally of the opinion that there is nothing wrong with the use of a bleed valve, only the moron that fiddles once it's been setup.
3. Chipping an RST only removes the boost limit doesn't it rather than anything else more clever
Old 29-01-2009 | 05:06 PM
GUZZLER's Avatar
GUZZLER
he sounds full of shit, nothing wrong with a bleed valve, crude but works, i'd like to him tension the actuator after its just done a few runs in the dyno
Old 29-01-2009 | 05:11 PM
Oranoco's Avatar
Oranoco
Apparently the car used to belong to a guy who works for Burton and he himself used to. This doesn't render me full of confidence after their technical man told me no RST could do more than about 200bhp and all the cars claiming bigger figures were full of shit and the dyno graphs were doctored
Old 29-01-2009 | 05:16 PM
Stu.H's Avatar
Stu.H
Bleed valves are FINE.
NB: ONLY F SET UP BY YOUR TUNER!!!
Karlos did explain somewhere once why he uses them on his low power rst conversions, cant remember what he said tho.
Old 29-01-2009 | 05:29 PM
jammy86's Avatar
jammy86
The guy is correct really, they are not the correct solution in an ideal world but people want a low cost easy to do method of changing boost, so they are used.
The controlling of the boost I'm not sure about because I dont know how the ERST ECU works, but it should be possible as it has an amal valve doesn't it? Provided that you can modify the point at which the amal valve kicks in then yeah its totally possible.
JAmes.
Old 29-01-2009 | 05:39 PM
Rax's Avatar
Rax
Wouldnt it be safer just to have a hi/low boost switch ?,that way after its been set up there is no twiddleing the bleed valve and risking detonation.I have never used a bleed valve because it would be unsafe in my hands.Car setup,used to it "twiddle twiddle" more boost BANG !!
Old 29-01-2009 | 05:46 PM
Stu.H's Avatar
Stu.H
Hence my post, your tuner uses it if necessary, and you pretend its not there!!
Old 29-01-2009 | 05:51 PM
Oranoco's Avatar
Oranoco
Exactly.
Problem is there are a large number of gibbons out there that will insist on having a tinker, blowing their car up and then blaming the bleed valve when it was in fact their stupidity that caused the problem.
Old 29-01-2009 | 06:09 PM
Rax's Avatar
Rax
Originally Posted by Oranoco
Exactly.
HA HA,I think thats always going to be the case,the only reason I dont mess with my sapp is I know the cost of parts if it goes wrong.Everything else I have owned I have always tried to make it faster one way or another.People cant help themselves but mess.
Old 29-01-2009 | 06:15 PM
Stu.H's Avatar
Stu.H
A friend once pulled the hose off the ecu on a s1
HOW FOOKIN FAST
^^ not recommended
Old 29-01-2009 | 06:23 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
oranoco th eguy is right you best go back and apologise lol
the ecu has a mappable ignition rev limit, full speed pressure ignition map tables,ect ignition table act ignition table,etc etc it also has a boost map which is rpm/ pressure /ect/act mappable. As well as many other functions
Old 29-01-2009 | 07:08 PM
Oranoco's Avatar
Oranoco
So if the ECU is so functional why don't we have more than a boggo shitty chip available?
Old 29-01-2009 | 07:19 PM
xr2i-carl's Avatar
xr2i-carl
what a doughnut
Old 29-01-2009 | 07:29 PM
Turbosystems
Super Moderator
there are proper mapped chips available and has been for years since the 80's
we still sell them and have them in stock and can programme them whilst you wait
Old 29-01-2009 | 07:30 PM
Oranoco's Avatar
Oranoco
Well there you go. I am learned
Old 29-01-2009 | 07:32 PM
Paul_RS's Avatar
Paul_RS
Well i'm going to disagree with you, home built ones can be fine.
We've done a few with MSD kits and never had any problems. As long as you get proper checks done by a pro afterwards.
Old 29-01-2009 | 07:37 PM
Turbosystems
Super Moderator
www.turbosystems.co.uk
prices are on my web site Ive been dying to be able to post that for years
Old 29-01-2009 | 07:47 PM
Oranoco's Avatar
Oranoco
Need to update your VAT though mate.
Sure it'll be of use to people. I'm not planning on taking mine much further now
Old 29-01-2009 | 08:44 PM
Rax's Avatar
Rax
So you have just answered both of the posts,mine and yours.I said once set up dont mess,2 way switch =safe if properly set up.You said about having it checked once you have installed the proper stuff which I also agree with.Fact is people dont.They mess because they know better or nothing and then dont have their diy checked because they think its dead fast so it will be ok.
tankybaby66
06-02-2016 02:24 PM
01-11-2015 06:53 PM
Mc5506
05-10-2015 09:57 PM
DAZZER
30-09-2015 08:43 PM
fordrallycar
30-09-2015 07:57 PM
Quick Reply: ERST chipping and use of bleed valves
