Engine looms
Old Nov 24, 2004 | 06:37 PM
Ratty's Avatar
Ratty
Default Engine looms
Whats the difference between the 2wd saph engine loom and the 4x4 saph loom
Old Nov 24, 2004 | 08:11 PM
SPADGE's Avatar
SPADGE
The 4wd one has a number of block connectors in it and is in about 3/4 pieces
Where as the 2wd one is a single piece with no joins at all!
Old Nov 24, 2004 | 08:21 PM
ECU Monitor Enthusiast
Dont forget, electrically, the 4x4 loom Throttle posistion connector is wired different .
Also, there may also be extra connectors for a lambda and knock sensors.
Old Nov 24, 2004 | 08:29 PM
Ratty's Avatar
Ratty
Will the saph 4x4 engine loom connect up to a 93' XR4x4 car loom, as this would save me ripping out and replacing the car loom for my 2wd saph loom
Old Nov 24, 2004 | 08:31 PM
Ratty, A good question which I cannot answer - Sorry
Old Nov 24, 2004 | 08:49 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
The looms will go on any car as they dont need anything from the original loom to run.
Old Nov 24, 2004 | 08:59 PM
Ratty's Avatar
Ratty
They do, plus you need to wire the dash in
Old Nov 25, 2004 | 02:35 PM
Ratty's Avatar
Ratty
Up (hopefully for an answer)
Old Nov 25, 2004 | 02:42 PM
foreigneRS's Avatar
foreigneRS
Testing the future
it won't plug in directly, as the connectors are different.
i've used a 2wd engine loom into a cos 4x4 vehicle loom before.
it should easily be possible. you will just have to do a bit of soldering. i have the information somewhere on what wires are what that you need to connect up. for example, green is rev counter, one is for temp sender, one for oil pressure, etc. will see if i can find it, although i have to leave in a few mintes so can't promise it.
Old Nov 26, 2004 | 12:20 AM
Versus_Creations
Ask me a question!
Power (Main line via fuse link) Red/Blue
Trigger live (+2 on ignition) Black
Fuel pump - Red/Black
Coil/Tacho - Green
Oil pressure - brown/green?
Water Temp - Brown/green?
Oil pressure and water temp could be wrong way round but you will soon find out if it is.
HTH
Regards
Jano
Old Nov 26, 2004 | 12:22 AM
Versus_Creations
Ask me a question!
BTW the above is for the 2wd type looms. Sum Alfa and VW will be similar
Old Nov 26, 2004 | 06:38 AM
foreigneRS's Avatar
foreigneRS
Testing the future
the 4x4 engine loom does not have the oil pressure included, it is in the vehicle loom.
big_Rad
Sep 15, 2017 09:36 AM
Marcus L
Aug 29, 2015 02:18 PM
Topjoe9
Aug 20, 2015 02:38 PM
muz
Aug 16, 2015 12:57 PM
Roosie
Aug 15, 2015 08:09 PM
