Etch primer
Old Jan 22, 2009 | 01:16 PM
RichieST's Avatar
RichieST
Default Etch primer
Hi all
I am going to be repainting my wheels in a couple of weeks time as they are getting quite corroded and look pretty scabby. I will be blasting out all the corrosion but probably leave the good paint on the wheels as it will take a lot of time to blast it all off.
Should I use etch primer first, or will ordinary primer be ok? Will etch primer be safe to use on top of old paint?
Thanks
Rich
Old Jan 22, 2009 | 01:46 PM
BigErn's Avatar
BigErn
What wheels are they?
Are you doing them with compressor and gun or rattle can?
Old Jan 22, 2009 | 01:52 PM
RichieST's Avatar
RichieST
They're the standard wheels off my st170. Just using a rattle can, i have done wheels this way before and they have come out alright. I know i'm not gonna get an excellent finish but its just to last another year or so until i will be replacing them!
Rich
Old Jan 22, 2009 | 01:55 PM
gingerxr2's Avatar
gingerxr2
normal primer will be fine,ive done em before and they have been sweet,sod paying for etch primer
Old Jan 22, 2009 | 02:58 PM
costina's Avatar
costina
Live long and prosper!!
Etch mate Upol
Paul
Old Jan 22, 2009 | 03:05 PM
RichieST's Avatar
RichieST
Ok thanks for the replies. If i do use etch primer, i presume 1 coat of etch then a couple of coats of normal grey?
Old Jan 22, 2009 | 03:11 PM
andy130's Avatar
andy130
2 coats of etch
2 or 3 coats of grey primer
wet sand
base coat
claer coat
Old Jan 22, 2009 | 03:17 PM
costina's Avatar
costina
Originally Posted by andy130
2 coats of etch
wet sand
base coat
claer coat
JOB DONE
Old Jan 22, 2009 | 03:20 PM
RichieST's Avatar
RichieST
Ok cool, cheers!!! Just so long as etch primer will stick to bits of paint ok
Old Jan 22, 2009 | 09:58 PM
BigErn's Avatar
BigErn
remove all the flaky bits of paint, feather the "sharp" edges of paint back with 240 grit. Key the full surface to be primed then fire away as said above
Old Jan 22, 2009 | 10:01 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
etch primer forms a chemical bond with metal so it wont flake off and prevents corrosion forming, its vital imo that any bare metal gets a coat of etch first
Old Jan 22, 2009 | 10:04 PM
BigErn's Avatar
BigErn
nice little explanation for those not knowing what etch primer is
Old Jan 22, 2009 | 10:28 PM
focus st2's Avatar
focus st2
From experience (painting cars too long basically) you'll need etch primer. Chromate etch primer helps adhesion of your 2k primer.
Try avoid etch from an aerosol can. When its applied from a spray gun its evenly applied and i feel you can get the product into the tight edges easier.
2 or 3 coats of 2k acrylic primer over your etch then you should be on the road to recovery
Quick tip; If your priming the wheels yourself dont force dry the etch primer (with a heat gun of by blowing air from the spray gun) it forms a skin on the top of the etch while its still wet underneath. If the 2k is sprayed over it then there is a big possibility your paint could peel off down the line. So leave it naturally dry
Hope this helps
Old Jan 22, 2009 | 10:31 PM
Toe Knee's Avatar
Toe Knee
Agree with the above if it want it to last then it will need at least a coat of etch, if its only a few small areas that are busted thru to bare ally thou mate u might find it cheaper to buy it in a can than gettting it in a tin and the thinner for it etc.
If the ally is in good condition and is prepped properly you can actually go wet on wet with etch ie get it all ready then dust a couple coats on then go straight on with a colour after its flashed, but by the sound of it u will need a couple coats of high build on it aswell!!
Old Jan 22, 2009 | 10:33 PM
JTECH James
Passion for Fords!
there are some very good rattle cans available these days though, u pol as said are really good.
you could warm the wheels up before applying the product to aid dying time
Old Jan 22, 2009 | 10:43 PM
focus st2's Avatar
focus st2
Yeah very true. Warming the wheels up before applying will definately aid with the drying. Problem with aerosols tho is that its next to impoosible to get even coats around the area. Etch dont have to be applied heavily anyway but if he's using aerosol 2k primer, basecoat and clear coat they never turn out 100%
But i suppose he only wants a another year from them until replacing
Old Jan 23, 2009 | 08:20 AM
RichieST's Avatar
RichieST
Thanks all for your replies and advice! We do have painters at work who could do them for me, but as i said i only really want a quick job done on them to tidy them up as cheap as poss as I will be replacing them soon anyway.
I'll go find myself some etch primer
Cheers!
Old Jan 23, 2009 | 08:26 AM
Smit's Avatar
Smit
The 60ft Launch King
Add to the saying above that the chemical bond is usually between lead chromate, ester and xlene.
For best results the surface MUST be clean and bare metal dry...
Wilsfoci
15
Mar 30, 2016 10:26 PM
155lee
Oct 24, 2015 11:11 AM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
Adz 131
Feb 28, 2005 11:00 AM
ProjectBobcat
Nov 5, 2004 11:50 PM
