Peugeot 406 experts
peugeot 406 diesel on a P plate
its got that keypad with number on to allow the car to start -
does anyone know what the keypad does to prevent the car from stating? does it cut fuel? stop pump? stop spark
does anyone know if you can by pass it?
edit: the key pad number is known but it does not work; the red light just flashes
Matt
Matt
if petrol you will have to pay for the bypass box/ pay someone to decode etc, if diesel i expect you will be able to do it yourself with a new stop solonoid on pump and maybe a new starter wire
normally with diesels, older ones like that yes, with a diesel engine its the stop solonoid that enables the engine to run / not run, and of course a starter to turn it over, on the pump look for the solonoid and see what wires are going to it, it will need a ign live feed, sometimes you have to put a new solonoid on with a single wire, solonoids are only about £15
i know this isn't gonna help but just in case somebody reads this etc
with this type of immobiliser, if you cant be arsed typing in the code or want to bypass it,
if you know the code type it in, then when the green light comes on just pull the plug out the back of it and hey presto no more immobiliser
its no use here csause you need to put the code in then green light on for it to work
sounds daft i know but trust me it works
DavidK
27-09-2015 02:55 PM
