Cossie Management or NMS??
#41
Balls Deep!
But anyway here is Christians post....
Myself and most people will take their word as gospel but you are entitled to your opinion........
#42
You obviously dont understand the difference between flow and boost hence why you dont get the illustration in my previous post.......
and again Stu's....
and again Stu's....
#44
RSTdave
So if you had another aftermarket management system you wouldnt need a crank sensor setup? Of course you would, a fixed setup like the Fiesta flywheel is not ideal either.
Basic ECU's use batch firing systems which do not require a phase sensor, when trying to get the best out of your engine these types of systems do not help. A sequential management system is by far better for many reason's.
Hence the reason that the cosworth management system works so well and for such little money.
Lets compare what you said about different management systems.
Cosworth L6 ECU £50-80
Cosworth Loom £100
Aprox prices..
Omex ECU £500
Autronic £1000
Emrald £450
Pectel T6 £1000
etc etc..
Looms custom made for any of the above £450
Now lets compare maping costs.
Cosworth £150 loads of tuners around the country
Any other ECU £300 - 500
So as for value for money i dont see your point?
Cosworth Loom £100
Aprox prices..
Omex ECU £500
Autronic £1000
Emrald £450
Pectel T6 £1000
etc etc..
#45
I have this intercooler setup and it is very, very good. However, if you're only wanting 220hp, a GRS would be much cheaper. Karl used to fit these on lower power cars, I'm sure he'd still do it.
Rick.
Rick.
#46
*** Sierra RS Custard ***
And I dont think you would see 5psi at high RPM on a 3.2L M3 engine from a T3, it would just be swallowing the air far too fast to even see that much boost I would imagine.
#47
Eruption 101.3fm
http://img.photobucket.com/albums/v7...6062006127.jpg
![](https://img.photobucket.com/albums/v713/gareth_r_uk/06062006127.jpg)
Fair enough YOU have no issue with it but your hardly pushing massive power and you will have limits in many places like injectors on high impeadance etc, also if you want your ECU maped how much will it cost using your batch firing system? you will find that you have other limits such as using a 3bar map sensor, yes it can be fitted and used but at what cost.? + Many other small things that make the difference.
With a Cosworth ECU you have no limits to components used.
As for the age of the loom, as long as you buy a decent one that has not been cut about and messed with, then check it with a multimeter and tidy it up it will be fine. My loom has been in and out of about 4 cars and still works with no issues. If you buy a crap loom off a random punk and hope for the best instead of buying one from a know trader you deserve to have issues for trying to cut corners.
Then your non realistic price for mapping cossie managment pmsl, karl norris might get it running for £150 lol, and you're saying more people have the software etc to map cossie ecu's than anything else? Don't seem to be that many tuners who can live map a cossie ecu and the ones that can charge the money.......
Ahmed
Paul Hills
Jano
ATM
NMS
T&R
Stu
will all do the mapping for around that money if you have a decent base to start from.
#48
Pal you could get any management system 'tweaked' for little money if you had a good base map....why is cossie management gonna be any cheaper than anything else? Oh and i've already had my ecu mapped....and wtf do you know about my car anyway?! And i'm on about the brackets i've seen on an original rst engine not a zt, it was a general statement as to the brackets and trigger wheels you see on the cam pulley on some conversions like the first pic you used. And 2nd hand looms, not something i'd want to use personally, multi meter can only tell you so much without picking the whole loom apart. Just seems to me if you're doing a management conversion i'd rather use new components/wiring and do the job properly once imo....and it is only my opinion mate everyone's entitled lol
#49
Not as neat? LOL. How is this not neat? You cant even see any of the sensors or parts your talking about.
![](http://img.photobucket.com/albums/v713/gareth_r_uk/06062006127.jpg)
Just underneath the cam cover breater
But you already knew that didn't you.
As for this thread, if you only want 220bhp why go to the lengths of a cossie management. If you have a feeling you might want more then spend the money, Oddkid, NMS, Field Motorsport as well as many others (MSD?) would be able to do the conversion for you
Edited to add: The Oddkid conversion looks a lot neater with the cam sensor than other I have seen
#50
Eruption 101.3fm
Yes it is visable however very neat. It is on the left hand side of the breather pipe on the left of the rocker cover.
So thought i would show one on a CVH.
![](https://i88.photobucket.com/albums/k184/grsford/12062008057.jpg)
Yes obviously i did know that, however this cannot be used with the cosworth management setup without having custom cam profiles on the trigger on the cam or made something up which could be adjusted, but then that would make it very hard work to adjust or setup. Hence why the best method is used as you can see.
#52
i just brought full cosworth engine management with msd chipped l6 ecu custom rst cossie loom all sensors brackets trgger wheel and pulleys trottle bodie greens 3bar map sensor ect all i diddnt get was the inlet and i payed £260.90 posted and £25 for the inlet /fuel rail and regulater bargain ive been quoted £350 fitted and set up if i get the old crap out and got a t34 for a £120 off ebay aswell so do some hunting and you'll save shit loads as for nms they are one of the best so its upto u.
#54
I've decided to go the Cossie Management Route but now undecided who I want to set it up. I had this conversation with a mate last night, Going to source bits myself and then have it set up by Jano (oddkidd) the only thing that concerns me is that I'm sure he only "live maps" them rather on the rollers? For slightly more money I could still go to NMS and have it set up by them. Still dont know what to do.
Funny that, I purchased the follwoing today:
Blue Injectors,
Fuel Regulator
Fuel Rail
Throttle Switch
ISCV
EFI Inlet
and a few other bits and bobs for £170 - not quite as cheap but I'm getting there slowly and surley.
Blue Injectors,
Fuel Regulator
Fuel Rail
Throttle Switch
ISCV
EFI Inlet
mk3ste
17-10-2021 10:09 AM
deathrider666
28-09-2015 06:12 PM
centralina, chip, conversion, cossie, cosworth, live, management, map, mfi, motorsport, phase, pulley, rst, sensor, set, turbo, zetec
