Flow rates, info, data for YB heads?
Can't belive people haven't asked to see flow data, if not from their actual head then the development head.
Its not giving any secrets away. Its like asking for dyno results showing bhp. It doesn't tell you specifics about how it was tuned
Doug, I have many maps for differing engines and states of tune.
If you know the boost pressure, fuel pressure, target AFR and injector types, I can tell you what the injector duration is for any load/rpm and you can work out the air flow from that !
LOL... headache !!!
LOL... headache !!!
Wouldn't you also need the BSFC?
Found some data. The CNC heads site states they measured a stock head at 122cfm @ 10" WC.
Their big valve ported head flows 191.5 @10".
Only problem is under the chart the small print states the flow rates were done at 0.5" (12.7mm) valve lift.
Passion for Fords!
doug check www.cncheads.co.uk
im sure they give some flow info on a std and ported yb head on the yb products page. it may be of some use ..
edit, just seen youve done that lol
Mark
Si B
12-09-2015 06:49 AM
