boost problems
Old Jan 13, 2009 | 04:40 PM
  #41
JTECH James's Avatar
JTECH James
Passion for Fords!
you will never get it anywhere near right with it running the wrong injectors mate,
you have to run too low a fuel pressure imo. closed loop doesnt work over 4 psi of boost....
all your going to do is cause yourself lots of damage.
you HAVE to get these done before you can go much further with diagnoses..
Old Jan 13, 2009 | 06:18 PM
  #42
andy escos's Avatar
andy escos
still running the correct pressure m8 not dropped it at all ,i will get them when i get some money.
Old Jan 13, 2009 | 06:57 PM
  #43
JTECH James
Passion for Fords!
in that case it must be stupidly rich off closed loop, id put money on this being the problem.stus chips are bob on, so there is no way you can run an 83lbs chip on 1000cc injectors without issues!
Old Jan 14, 2009 | 10:35 AM
  #44
Jim Galbally's Avatar
Jim Galbally
listen to JTECH! what you are doing is VERY wrong!
Old Jan 14, 2009 | 09:10 PM
  #45
andy escos's Avatar
andy escos
i know what i am doing isnt ideal but the afr,s are quite good considering &as soon as i get some money they are the next thing ill buy.& i am sure the fuel injectors are not the problem that would not give me uncontrolable boost.
Old Jan 14, 2009 | 09:12 PM
  #46
JTECH James
Passion for Fords!
no, but you are risking a meltdown or causing severe engine damage while attempting to find the problem lol
you need to continuity check the earth feed to your ecu from the air injectors, and imo then get your ecu checked out.
Old Jan 14, 2009 | 09:29 PM
  #47
andy escos's Avatar
andy escos
yes i totally agree& iwill get the misses to post ecu with chip to get both checked out.
Old Jan 14, 2009 | 09:49 PM
  #48
Jim Galbally
no mate you dont kow what youre doing, the fact you even tried it proves that... lol
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
