why use group A fuel pumps?
Old 22-11-2004 | 07:02 PM
mmanse's Avatar
mmanse
Default why use group A fuel pumps?
Can any one tell me the differance between a group A fuel pump and standard one? running my saff on greens and maybe changing to blues
but have been told i need a group A pump as the one on it would not cope.
Any advice would be great!
Old 22-11-2004 | 07:14 PM
john's Avatar
john
I think the standard ones are good for 400 horsed AFAIK. Has to be in new condition though not one sat on the car for years
So you would be nearing your limts.
Old 22-11-2004 | 07:15 PM
The DIVA's Avatar
The DIVA
The 044 group A pump will flow more fuel mate keeping the fuel pressure and delivery constant at high boost/revs so it dont go lean on ya and melt a piston !!....
morpheus1967's Avatar
morpheus1967
Its to do with the amount of fuel the pump flows, i beleve a standard one is ok for blues but best to be safe and spend 170 odd quid to gain a grp a 044 item.
Old 22-11-2004 | 07:45 PM
NUTS RuS's Avatar
NUTS RuS
As above, it flows more but it is then limited by the regulator so you'd also be better off uprating the pressure regulator too
Old 22-11-2004 | 08:39 PM
the original's Avatar
the original
reason i bought one was the built in pre-filter which a standard pump doesn't have, shagged a couple of standard pumps due to debris in the vane (no in tank filter on one of my cars)....
Old 22-11-2004 | 08:47 PM
morpheus1967
NutsRUS, standard fuel reg is fine on a saff for well over 500bhp
Old 22-11-2004 | 09:28 PM
NUTS RuS's Avatar
NUTS RuS
May well be fine .... but its about 15 years old by now, and you will be hitting it with greater pressures all of a sudden. Small things are often overlooked until your tuner gets it and stuff like this starts to fail quite quickly once pushed I believe, then it costs double
Old 22-11-2004 | 10:25 PM
ImaRacing 700's Avatar
ImaRacing 700
£170 Try me!!!!
NUTS.....sorry you DO NOT need to touch the fuel pressure regulator!!!!At around 380bhp the std pump begins to major struggle meaning melt down!
The std pump is good for up to 380bhp...the 044 to around 550bhp.
Old 23-11-2004 | 12:32 AM
tracktoy's Avatar
tracktoy
so how much for a 044 pump?
Old 23-11-2004 | 07:13 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
the grpa fuel pump is good for getting a lot more fuel up to the fuel rail. Its doesnt however mean that your fuel regulator can handle the extra fuel that is being thrown at it.
Old 23-11-2004 | 07:25 AM
swerv's Avatar
swerv
std regulator will be fine , yes change to the 044 and do some re-wiring as this is very important as well
Old 23-11-2004 | 10:28 PM
mmanse's Avatar
mmanse
thanks for the advice! group a fuel pump it is and new fuel regulator just to be safe. Is that worth uprating or should i just put a standard one back on?
JK12
33
26-04-2021 12:09 PM
jessie_rs
62
06-08-2019 09:27 PM
155lee
27-10-2015 04:55 AM
15
07-10-2015 03:43 PM
tib2220
14-09-2015 12:33 PM
Quick Reply: why use group A fuel pumps?
