help engine build advise
Old Dec 10, 2008 | 06:22 PM
rs tingle's Avatar
rs tingle
Default help engine build advise
h there ppl i posted a thread abit ago on where i could get me engine rebuilt an i thought id have a bash myself as it was cheaper and as iv heard its dead easy to do. right where i am at the mo .iv got the engine stripped down to a bare block im just stressin on what size pistons i need after i get it bored or re honed .and if it needs std main and big end bearings or if i need oversize bearings i think the engine has never had a rebuild be4 i think its all std the bearings all seem to still have there original bearing stamps on them thats why im asumeing there std but i dont wana take my own judgement .any help welcome or critisisum psml
Old Dec 10, 2008 | 06:24 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
what engine is it....
Old Dec 10, 2008 | 06:29 PM
rs tingle's Avatar
rs tingle
ooops it would help lol 200 block yb 2wd .plus there is a lip at the top of the bore does it need a rebour
Old Dec 10, 2008 | 06:34 PM
JTECH James
Passion for Fords!
it will end in tears if you need to ask these questions imo.
the yb will bite you if you get anything wrong bigtime....
in your position id get a pro to build her pal
Old Dec 10, 2008 | 06:37 PM
bud-weis's Avatar
bud-weis
Football Cwazy
Bigger bearings will have .25 or .50 markings in them. When reboring go to the smallest size needed, ideally .25
It's easy enough to do, but some knowledge would be useful to avoid heartache
bud-weis's Avatar
bud-weis
Football Cwazy
Old Dec 10, 2008 | 06:42 PM
westus1's Avatar
westus1
its a costly mistake to rebuild a yb with no experience
if your not sure about pistons and bearing sizes then i'd advise leaving it to an expert
if you are sureyou want to try it yourself then take every part to an engineer to get properly measured and checked, it might cost you a couple quid for this but at least then it'll have the correct parts,
dont try rush the build, take twice as long as you think it should take and tripple check everything,
imo a yb is a heavy stressed engine and so not a good jigsaw puzzle to start playing with as everything needs to be perfect or it will go horibly wrong
anyhow i do admire your courage for trying but just be very careful and seek expert advice at every point
Old Dec 10, 2008 | 07:17 PM
rs tingle's Avatar
rs tingle
i just wanted to save a bit more cash really .i just want to learn really id like to now more about the engine .i dont mind if it all goes tits up at least i had a go really i luv me cars an just wana now more im always palyin wid engines but im a welder by trade .i have done bearings change on me old 4x4 saph cossy be4 but not pistons .i changed cambelts an seals to but not a full build . i now its sad but i sit on me breaks at work an just read me 2wd cossy manual just to get a bit more info .as my engine is all in bits if i took it to a builder would they turn me away an not want to now or would they charge me more as its all in bits rather than a full built engine .and what sort of price would i be looking at for a std rebuild thanks ppl for ya replys
Old Dec 10, 2008 | 07:46 PM
Rossco's Avatar
Rossco
Ive assembled a couple of engines and its not that hard with a manual etc. Trying to work out sizes and bores etc are not so easy I get help from a local machining shop/engine builder.
Old Dec 10, 2008 | 07:48 PM
stevenebm's Avatar
stevenebm
post whore
id love to rebuild an engine.be great satisfaction if you managed to get some good figures out your own work.
Old Dec 10, 2008 | 08:10 PM
westus1's Avatar
westus1
any engineer will have a look/measure for you
if its just a basic standard build then by all means have a go
they are old engines and so very basic realy
just dont go trying to go for much more than standard power or this will get harder
bit more involved when you got porting, mod'd valve seats, cams to time/dial etc
but as i say take more time than realy needed and triple check everything
and lub everything up proberly, i.e pistons, cam journals, big and small ends, mains etc
Old Dec 10, 2008 | 09:10 PM
rs tingle's Avatar
rs tingle
cool im sure if i get if i get stuck you peeps will help me .i think 320 bhp is enough for me any more id but it in2 a tree or sumat im mad enough with out nearly any more bhp than that lol .ill keep yas all posted wid the progress im gona go see an engineer the weekend so see how things go thanks ppl for ya comments .
JoeyBoyden
Jan 4, 2024 02:36 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Adam-M
Aug 26, 2015 05:53 PM
Bailes1992
Aug 16, 2015 07:14 PM
Zoggon
Aug 10, 2015 10:39 AM
