fuel pump relay
fuel pump relay
think i have an issue with the relay,,last time out with the 3 door when i hit a rumble strip or bumps on the road the fuel was cutting out.
I checked the pump wires,and they where fine.
Any how i had the car booked in for an MOT today so last night i decided to conect the battery, and check the usuals , light s ect.
Car started and died , wouldnt restart.??
Checked at the pump and there was no power , at the fuse was ok, so after a few calls the idea was to check the relay under the dash.So some how i got myself head first under there, found 2 yellow relays, proded them but dont know which is for the fuel pump.
Tried the car after a prod of the relays and it fired straight up.
So i recon one of the relays is ifffy, but which one , is there any way of telling the fuel relay , numbers markings ect???
all help appreciated
Look for the relay with a BLACK/RED wire in it, as this is the output from the relay to the pump itself(through trip in boot, if 3 door has this, but don't think they do ?)
Received 1,044 Likes
yeh thats correct 1 yellow relay is for the engine ecu and the other is for the fuel pump. I got told that the relay is a common fault on the cossies. Its one of the first things i changed when i got mine.
JK12
33
26-04-2021 12:09 PM
155lee
24-10-2015 11:11 AM
