Playstation 3 setup NOT hdmi Help please!?
Old 09-11-2008, 08:43 PM
RobCarden
358bhp
RobCarden's Avatar
Default Playstation 3 setup NOT hdmi Help please!?
ok...
used to use a hdmi cable then the cat attacked it and distroyed the socket on the tv
so until the tv is fixed i bought a composite lead with a playstation socket on one end and 3 phono plugs yellow red white and a s/vhs plug on the other.
when they are plugged into the tv nothing comes on screen
tried the svhs plug on its own and the yellow video phono plug. still nothing... checked the tv is on the right aux/av in channel. tried them all....
any thoughts?
does the playstation 3 need something changing on it software wise form hdmi back to comp video.. not sure how i can do this without a picture tho!
cheers for any help or pointers....
Old 09-11-2008, 08:44 PM
RobCarden
358bhp
RobCarden's Avatar
i had to get the lead off ebay as i binned the sony supplied one.
this is the one i got from ebay
does the yellow phono plug need to be plugged in aswell as the svhs plug? surely its one or the other?
Old 09-11-2008, 08:47 PM
Harris.
Harris.'s Avatar
So your running a scart lead? Try unpluging it and using scart port 2 on the tv if it has one!
What tv do you have?
Old 09-11-2008, 08:51 PM
RobCarden
358bhp
RobCarden's Avatar
this one mate....
http://www.shop.bt.com/productview.aspx?quicklinx=56W6
Harris.
Harris.'s Avatar
Yellow white and red have to be pluged into the scart plug that comes with the console. the other black one on my set up goes from my hi fi to the side of the t.v (samsung plasma)
Old 09-11-2008, 08:52 PM
RobCarden
358bhp
RobCarden's Avatar
this is the manual for the telly...
http://marketing.prestigio.com/$Promotion/Datasheets/LCD_TV/P320DVDX/EN_P320DVDX_DTS_lr_0507.pdf
Old 09-11-2008, 08:54 PM
Harris.
Harris.'s Avatar
This
http://cgi.ebay.co.uk/Scart-to-SVHS-...1%7C240%3A1318
Old 09-11-2008, 08:56 PM
Harris.
Harris.'s Avatar
Ah yeah, you need to go to the settings on Your ps3. On there you set it to scart or hdmi (OUTPUT)
Jim Galbally
Jim Galbally's Avatar
if its connected but not showing anything then you'll need to reset it.
once you have it set to HDMI itll only output HDMI
if you havent already, comepltely disconenct the HDMI cable. do some googling on how to reset the display settings to get it to go back to cmposite
Old 09-11-2008, 09:03 PM
RobCarden
358bhp
RobCarden's Avatar
thanks for the replies guys....
i ll give those things a try.....
Old 09-11-2008, 09:06 PM
RobCarden
358bhp
RobCarden's Avatar
that makes sense.... however i have no working display to see what i'm doing on the ps3 settings
Old 09-11-2008, 09:08 PM
Harris.
Harris.'s Avatar
I did think that
Just wait till tomorrow and go get yourself a new HDMI cable
Old 09-11-2008, 09:09 PM
JTECH James
Passion for Fords!
JTECH James's Avatar
i think you turn it off on off on quickly on the rear switch, it goes back to default setting
Old 09-11-2008, 09:20 PM
RobCarden
358bhp
RobCarden's Avatar
I did think that
i can't it trashed the hdmi socket on the tv
jtechsaff - i know nothing about these things but i thought turning things on and off quickly fucked them up! might try it tho... gently
Old 09-11-2008, 09:25 PM
JTECH James
Passion for Fords!
it works....
Old 09-11-2008, 09:33 PM
Rick Astley
Never gonna give you up!
Rick Astley's Avatar
Press and hold the power button for 5 secs.. until you hear the second beep. Then it should go back to normal mode.
Old 09-11-2008, 09:35 PM
RobCarden
358bhp
RobCarden's Avatar
your right. cheers
- really pleased its sorted! cheers for the help everyone - nice one
timsrs
13-11-2018 11:48 AM
Fezman1
02-10-2015 01:22 PM
SMILER258
28-09-2015 09:04 AM
truffleshuffle
10-09-2015 09:35 PM
Rob_DOHC
Computers, Consoles and I.T.
15-08-2015 11:17 AM
Quick Reply: Playstation 3 setup NOT hdmi Help please!?
