is it safe to run 1.2 bar with standard ecu and no chip..200sx
200sx s14a
currently not even holding 0.9 bar but gonna get that sorted.
would it be dangerous for the engine tho?
got a few mods including upated fuel pump?
whats the deal?
whats the deal?
I wouldnt, When I turn up the boost on road S14s I usually dont go any more than 0.9 bar maybe 1 Bar max. And with that I always fit an adjustable fuel actuator to turn up the fuel pressure a bit.
http://www.motorsport-developments.co.uk/stus.html
'Under pressure' article in this case.
Not particularly wise.
ideally i would want to go to MSD as his knowledge seems endless! bit of a treck from london tho
1.2 bar is stretching the standard T28 to its limits, 1 bar is much safer. Also its worth noting that at this level of boost (1 bar), the standard "yellow" injectors will be maxed out above 6k rpm ish anyway
standard fuel pressure would be ok but an uprated pump, such as the common walbro 255 fuel pump is a must really
spec is in me first post... well the pump is...
big_Rad
15-09-2017 09:36 AM
kosienutter
31
22-08-2015 09:55 AM
