Help With Removing Gearbox
Old 19-09-2008, 03:18 PM
Gaz 88
Gaz 88's Avatar
Default Help With Removing Gearbox
is it as easy as just to unbolt it? the engine and box are out of the car
Old 19-09-2008, 03:22 PM
Luca
Lukesville
Luca's Avatar
Simple as removing all the bolts possibly the sump also bolts to the lower casing so remebr those ones.
Then just pull apart you may have to use a lever/pry bar to seperate them..
Old 19-09-2008, 03:25 PM
Gaz 88
Gaz 88's Avatar
cheers mate i will go and have ago!!
Old 19-09-2008, 04:33 PM
rst in breaking
rst in breaking's Avatar
you shouldnt have a problem mate, a doddle
Old 19-09-2008, 05:42 PM
Gaz 88
Gaz 88's Avatar
it was i was suprised at how loose the bolts were and i dont think its been touched since it left the factory!!
Fudgey
17-09-2015 01:06 PM
Si B
12-09-2015 06:49 AM
grishenko45
09-09-2015 12:58 PM
gingeRS
04-09-2015 06:29 PM
hopper350
04-09-2015 12:53 AM
Quick Reply: Help With Removing Gearbox
