Ap Brakes - 15" Wheels ??
Old 18-09-2008, 10:45 AM
Luca
Lukesville
Luca's Avatar
Default Ap Brakes - 15" Wheels ??
Has anyone run this set up if so which caliper disc combination.
Or have you the details of what brackets etc to fit on a mk3 Fiesta
Old 18-09-2008, 11:18 AM
VEEDUBBED
VEEDUBBED's Avatar
On my turbocharge Vw corrad i adapted the front Brembo calipers
fitted to the Lancia delta integrale evo-1,here in Rome 1 CANNOT change the original diameter of wheel which,in my case is 15inch so i could only use the O/E 286mm corrado disks.
The difference in braking compared to the old corrado single piston jobbies and the deltas is night and day.
Also worth noting is the evoluzione delta's Brembos are made of aluminium
unlike fiat coupe 20vt,Mercedes 230 slk,porsche ect that are cast iron 4 pots...
Old 18-09-2008, 11:26 AM
Matt Evans
Black Country RSOC
Matt Evans's Avatar
Give Martoon at Reyland a bell. I'm pretty sure you'd need the CP5200 4 pot caliper and a 285mm disc. If you go for a solid disc or disc and bell, either way Martin can make some bespoke brackets to fit the lot together.
Old 18-09-2008, 11:30 AM
Luca
Lukesville
Luca's Avatar
Thank you kindly for your replies I have given Martin a PM to see if he can help
Old 18-09-2008, 11:49 AM
Matt Evans
Black Country RSOC
Matt Evans's Avatar
Martin should be fine to do it. I used a firm called BG developments in Bromsgrove, worcs, to build me a 315mm AP 4 pot kit for my S2. They needed a hub, suspension leg and a wheel and they made the kit to suit. That used CP5200 calipers as well.
Worth the money though fella!
Old 18-09-2008, 11:51 AM
Munch
Mr. Sparkle!
Munch's Avatar
Luke what brakes you running at the mo?
Old 18-09-2008, 12:00 PM
Luca
Lukesville
Luca's Avatar
wilwoods at mo mate, they work but just do not have any confidence in them
Old 18-09-2008, 12:06 PM
Spiky
Spiky's Avatar
i'd like a set of 4 pots under my 15" wheels, but im guessing thats going to be quite expensive for the ap setup?
Old 18-09-2008, 12:17 PM
Matt Evans
Black Country RSOC
Matt Evans's Avatar
As a rough guide my 315mm kit was about £1200. That was back in 2001!
But, it was the most cost effective mod i ever did on my s2.
Old 18-09-2008, 04:31 PM
dave cos4x4
dave cos4x4's Avatar
Steve,
ask Tony, Nuts r us about a set for your car.
Old 18-09-2008, 04:52 PM
rsjp
rsjp's Avatar
bloody hell lofty
done that same kit for whiteys escort van with 15 inch rims for about £900
jp
yatta
21-05-2016 10:31 PM
Adam Graham
06-09-2015 06:04 AM
hopper350
04-09-2015 12:53 AM
cossirob
03-09-2015 09:17 PM
Quick Reply: Ap Brakes - 15" Wheels ??
