toilet flush
You'll probably need to replace the syphon as the plastic on the bottom of it has split. You can just change the plastic bit at the bottom if you don't mind taking the syphon apart. Piss easy job
Passion for Fords!
on mine you can adjust how much water is flushed by moving a rubber bung into a higher or lower hole on the side of the syphon jobbie,
on maximum, it gives enough water to shift even an arse splitting size turd, which normally take 3 or 4 flushes at other peoples houses.....
speaking of toilets, my mate has a good party trick, he stands on the seat and drops a log in from height, he gets them to stand up on end with there heads stuck up out the waterits truely shocking when your the next in after him
