Fitting dado rail?
Old Aug 31, 2008 | 01:50 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default Fitting dado rail?
Is it as easy as it looks? Our hallway is massive high ceilings, and to redecorate means painting the full lot, i was thinking about getting some dado rail so we can replace the bottom paper and paint it when it needs it instead of having to pay someone to re paper the full lot.
Its just the angles of the cuts for up the right hand side of the stairs x2 that im concerned about, the rest of it is straight lines so i reckon theyll be quite easy to do.
Wickes seems the cheapest place? And would MDF be better than wood as it wont have knots in it etc?
Any advice appreciated as need to get cracking on it, Finleys just ripped a big chunk of paper off the bottom today.
Sarah
Old Aug 31, 2008 | 01:54 PM
SteveH's Avatar
SteveH
Dead easy to do, just make sure its level!
Up the side of the stairs is easy too, offer it on the wall and rule along both sides, then offer it on the line of the stairs and rule both sides, so you should have 2 parallel horizontal lines and 2 parallel lines that follow the angle of the stairs. Where these two pairs of lines cross, draw through the two inersecting places and you will have the angle, which you copy onto your bevel
HTH's
Old Aug 31, 2008 | 01:57 PM
Dicko&Vacant
HTH's
The stairs has a large open bannister up 2 flights, not a wall either side.
Theres a border on there at the minute which looks pretty straight, i was thinking of just measuring from the skirting board up over in a few places and making sure they all correspond? If the border has been put up properly itll be a lot easier as i could use that as a guide then remove the border and re paper after fitting the dado?
Sarah
Old Aug 31, 2008 | 01:59 PM
SteveH's Avatar
SteveH
Are these the cuts you mean?
Imagine red lines are your pencil marks from the rail, and the blue line is what you set the bevel to, just read my explanation and its pants
Old Aug 31, 2008 | 02:02 PM
SteveH's Avatar
SteveH
Sarah
Or do that, my drawings not relevant is it
Yeah just measure up from skirt/floor then double check its level
Old Aug 31, 2008 | 02:03 PM
Dicko&Vacant
yep theyre the cuts i meant, i couldnt understand your explanation that makes a lot more sense thanks
Dicko&Vacant
i just dont wanna try fitting it and end up with a proper shonky donkey looking dado lol
Old Aug 31, 2008 | 02:04 PM
SteveH's Avatar
SteveH
No problem
SteveH's Avatar
SteveH
Know what you mean, i've seen some shockers before!!
Old Aug 31, 2008 | 02:12 PM
Dicko&Vacant
Ill just have to be mega careful, now gonna have to measure up see how many million metres we need
Old Aug 31, 2008 | 02:29 PM
mrjenrst's Avatar
mrjenrst
dado is piss easy.
Well appart from the stairs i had to do in my house from bottom of stairs to the top has 6 mitre's
It was a bitch to do but look's the bollocks
Old Aug 31, 2008 | 02:52 PM
Dicko&Vacant
itll just break the walls up as they are all around 12ft ceilings, then theres a really high bit up the stairs, should bring it down a bit
Old Aug 31, 2008 | 02:53 PM
dojj's Avatar
dojj
Resident Wrestling Legend
drill some hole sin the dado rail before it goes up
then stick it on to the wall along the pre measured level lines (don't measure from the skirting board as there is no reason thats going to be level)
drill holes into the wall through the predrilled holes in the dado
they don't have to be big
use them hammer fixings to bang them in and job done
if you want to be sepcially trick, use something to cover the holes with (normally use soemthing like gripfill if it's going to be painted, else drill some plugs out to cover the holes and glue them into place)
done in a day
3i Jim
Nov 20, 2015 05:12 AM
wheelwizardrefurbs
Aug 29, 2015 09:25 AM
Prickly_buzz
Aug 25, 2015 11:33 AM
C2 MAK
Aug 20, 2015 09:46 PM
Roosie
Aug 13, 2015 09:38 AM
