zetec turbo
#201
pa sjo/will as your good with the turbo graphs whats it like if i was to use a gt2860rs on a 1600 cvh to make 300bhp at fly with a flowed head etc as i can't find the t34 graph you posted above you got a link to a site with t3 and t34 graphs i've got the graph for the mentioned turbo but want a second opinion as to if turbo would be suitable
sorry gary for hijacking thread
#202
its running 20psi mate ,and had the management from my cvh turbo engine its just been remapped.ps i made both the manifolds.
#203
Colossal Pervert
#205
pa sjo do you have i link or place to go for those t3/t34 graphs you post up i've got all the gt series graphs but can't find standard turbo specs think that engine needs a little more fuel low 12's is a bit lean is it not
#208
escort mk4 cossy 4x4
He's on a T3, it would hold onto the power a lot longer on a T34 potentially, also I bet he wasnt on a very modified head or a lairy set of cams like Will is discussing.
The torque he made though, just to put things in perspective, is sufficient for 350bhp @ 8000rpm
So to make what will is saying, you can still allow for the fact the VE drops at revs increases and still consider it reasonable on 9psi
It certainly wont be revving to 8k thats for sure, its only got standard cams, valves and head, the tweaked bits werent required for his power aim.
