Cars getting black flagged on track for INDUCTION noise- What cars have?
#81
the lotus exige's suffer from noice due to induction (sean bicknell is one)
i've heard some gti6's with ITB and carbs, and they not THAT loud, but some are louder than others
i heard the chosen cam can affect the noise level???
just my two pence worth
#84
The only way to reduce induction noise would be to use an airbox like on a production car. The volume of the box will effect the frequency and the volume of induction noise.
Big cams can also actually increase induction noise alot as the pressure difference between the manifold and the engine changes quicker as the valve is opening faster.
#85
DEYTUKURJERBS
Bloodyhell
Everyone im sure is mentally able enough to work out HOW to reduce induction noise, the question is, at what level does your usual turbo and cone filter cause so much fucking noise it trips the noise meter.
#88
i would say that a cosworth variety'd turbo engine unless someone has done something totally ridiculous with it will not be able to produce anywhere near 100db on pure intake noise alone, especially not on driveby, in fact i would place a safe bet on that, having to deal with noise on a regular basis and having been noise tested on a regular basis.
alot of the biggest issue related to INDUCTION, is that when a restriction is placed in the inatke the noise of the air trying to be pulled through this can be very loud at full boost/high revs.
#91
DEYTUKURJERBS
Sierra did. Bedford and Donno.
Deffo induction... my own fault really. Silly metal thingy cone filter unboxed...
Would have been something that was definately modded if I had kept it.
#93
Caraholic
Stav,
I believe my car was black flagged for induction, as I cut the front of my airbox away even further a few weeks ago, and I have never had problems before. I only "just" tripped the noise meter at 2.0 bar of boost as well, with 98.7dB, so my exhaust works and I believe that 1.8 bar would have sorted it, but I had to drop it down to the lowest setting, as I was already on position 2 (of 4), which equates to 1.4 bar creaping to 1.6, as the boost curves with the roller-bearing turbo have gone to rat-shit and need adjusting, so I have my 1.4, 1.6 1.8 and 2.2 bar boost settings.
Incidentally, CSLs have huge problems with induction noise over exhaust noise.
#94
#95
at the risk of getting completely cunted off for being no help whatsoever...
not sure if this is of any use as i'm nto sure how the noise levels are tested at trackdays but i've seen a golf with an audi turbo engine penalised at lydden due to induction noise. i believe the basis for it being stated as induction rather than exhaust was that it passed the static test when revved to whatever rpm it was (despite being fuck off loud) but was caught out whilst racing by a trackside mic. presumably the induction bit comes from the fact that it was fine on static?
was running a turbo about gt30 (not a lot of use i know - sorry!) sized with an induction kit (kind of like those old viper things you used to be able to buy, and maybe still can) with the cold air feed out the front headlight.
#98
Got black flagged at dono for induction in the morning at 25psi.....
In the SO turned it down to 18...
Last sessions i turned it up to 2 bar and never got black flagged.
Wind affects dono in a big way....
Ran the time before at full boost no issues.
Cone filter - no airbox.
Bedford - 2 laps on 15psi - off - worse track in the uk bar none.
Croft, brands, silverstone, cadwell and oulton - never had any issues with induction.
Stu @ M Developments
41
21-08-2015 06:47 AM
track.focus'd
12-08-2015 05:53 PM
Versus_Creations
24
05-08-2015 09:32 PM
CabrioTurbo
01-08-2015 11:04 AM
