Why does my washing machine stink?
Old Aug 20, 2008 | 07:21 PM
RichieST's Avatar
RichieST
Default Why does my washing machine stink?
Hi all
Got a zanussi washing machine, its about 4 months old. Basically, its stinking the house out! Just smells of manky water inside the drum and in the powder tray bit.
There was some standing water inside the seal so i've cleaned all that out but it still stinks! It only really gets used at the weekend, where it does about 4 washes, nothing particularly dirty, although I did put my trainers in it the other day
Anyone know what can be done with it?
Thanks
Rich
Old Aug 20, 2008 | 07:24 PM
alan12112's Avatar
alan12112
Focus St mk2 310 bhp :D
Filter?
Have you cheked it?
kevnoize's Avatar
kevnoize
RsTurbo crewe ina corna.
wait till u smell the drainage hose sick.
i do house removals and have to move alot of washing machine's n some of them smell fuckin rotten i dunno why tho...
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
Do a 60 degree or hot wash with a couple of cups of white vinegar. If you dont have white vinegar then put a tiny bit of bleach in.
Obviously do it as an empty load.
Clear the seal on the door too of any water that has collected. 4 month old washing machine shouldn't really need the filter checking surely?
Old Aug 20, 2008 | 07:26 PM
nickscunny's Avatar
nickscunny
do a maintainance wash once a month using a cleaning detergent like Oust.....
89xr2's Avatar
89xr2
Brap!
Do you leave the door open after a wash to allow it to dry? if you keep the door shut it will start to stink...
Old Aug 20, 2008 | 07:27 PM
RichieST's Avatar
RichieST
thanks for the replies, forgot to mention, I have checked the filter, and its all clean in there. I've been reading through the manual and it says use biological powder on a hot wash, so will give that a go!
Rick Astley
I forgot to mention, stop shitting yourself.
Old Aug 20, 2008 | 07:29 PM
cossie604's Avatar
cossie604
ditto....we lernt that one
Old Aug 20, 2008 | 07:40 PM
pee vee's Avatar
pee vee
busted Richy!
would help though!
Old Aug 20, 2008 | 07:41 PM
NUTS RuS's Avatar
NUTS RuS
Its simply not getting used enough.
Split the washing up to run mid week and weekends if you can.
It will clear itself.
Old Aug 20, 2008 | 07:43 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
2 things to do,do a hot wash 90oC once a month,if u got a dishwasher,chuck 2 tablets init and run a 60oC wash and use soda crystals there cheap and work well!
next thing is to check the drain hose,does it go to ur sink?if it doing straight down to the washer?if it is chances are wen u put water down ya sink,its back flushing into ur washer,
Old Aug 20, 2008 | 08:02 PM
RichieST's Avatar
RichieST
thanks again for he replies! I walked up to the local to get some bio powder and a bit of calgon for good measure. Went up in my t-shirt as it was warm and quite pleasant, when I waalked out the shop it was cunting down, so got fooking soaked
Just put it on at the 95 degree 'service wash' with the bio powder and the calgon, so hopefully that should sort it!
I have tried to solve my incontinence problem, I guess my mother could never be bothered to potty train me
Will let you know how it goes!
Old Aug 20, 2008 | 08:57 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Our washer is used 2-3 times a day and it also stinks
Though we do leave the door shut but i might start leaving it open when im not using it see if it helps.
Do a 60 degree wash once a week as well but still doesnt get rid of it
Sarah
Old Aug 20, 2008 | 08:59 PM
kevnoize's Avatar
kevnoize
http://www.youtube.com/watch?v=gg2JQzDPPj8
sorry had 2 be done haha
Old Aug 20, 2008 | 09:11 PM
NUTS RuS's Avatar
NUTS RuS
Sarah
If your using it daily and it still does it your running too low temperature washes and not using enough powder / liquid.
Its the bacteria forming on the inside of the drum that is the smell.
An increase in temp and powder will wash away / disolve the bacteria.
Old Aug 20, 2008 | 09:14 PM
orion_crazy_carl
orion=mini saff
dont use calgon,its a load of uselss shit thts a waste of money
Old Aug 20, 2008 | 09:16 PM
Dicko&Vacant
95% of my washes are 40 degree cottons, the odd one is 60 degree cottons
and i use bold 2 in 1 capsules
Sarah
Old Aug 20, 2008 | 09:25 PM
Lee Reynolds's Avatar
Lee Reynolds
Its hard leaving the door open when your little'un wants to swing on the bugger
Old Aug 20, 2008 | 09:37 PM
Csm's Avatar
Csm
Yep ours stinks aswell ............ the only time its not used is the middle of the night
And same problem............ i have a nutter of a toddler for a son and he wont leave ther fucker alone if the door is left open
Why would mine constantly say its un-balanced throughout the cycle and doesnt spin dry properly ?? and the washing is sodden wet still ??
The machine is level and doesnt rock about ??
Old Aug 20, 2008 | 10:13 PM
Dicko&Vacant
ours has a digital front, finley knows which ones turn it on
thank foook for child lock
Old Aug 20, 2008 | 11:20 PM
neilm's Avatar
neilm
We had a Zanussi, nice machine, ended up ditching it because it wouldnt drain the water out, so thought it was fooked, when plumbing in the new washing machine discovered the drain was blocked and it fookin reeeked
Make sure where it empties is clean too
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
155lee
Oct 24, 2015 11:11 AM
