zetec turbo using c20let pistons, how much boost?
Old Aug 19, 2008 | 10:53 PM
rst in breaking's Avatar
rst in breaking
Default zetec turbo using c20let pistons, how much boost?
how much boost have you guys run on c20let pistons in your zetec turbos? (without pistons being skimmed)
Old Aug 19, 2008 | 11:02 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
as much as the mapper can map in with out det. i pritty sure its all down to intercooler size fuel grade ect ect
Old Aug 19, 2008 | 11:04 PM
clarke5700's Avatar
clarke5700
as much as the mapper can map in with out det its all down also to fuel grade charge temps ect ect
rst in breaking
im trying to work out weather i should have a fraction off my pistons or if they can reach good boost levels no prob, thinking of it as the pistons are coming out to change the rods anyway
Old Aug 19, 2008 | 11:05 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Strength wise you will have no problems.
You need to work out your CR though. get some measurements!
Old Aug 19, 2008 | 11:07 PM
rst in breaking
not too sure how tbh, was thinking of taking into burtons to work out a nice compression to run biggish boost, what compression ratio do you think id want for say 25psi? through a boost controller obviously lol
Old Aug 19, 2008 | 11:10 PM
JonnyBravo's Avatar
JonnyBravo
I wouldn't machine anything off those pistons if your going to push the power but definately check the c/r as I'm sure they come out at something very high when using them on a zetec
Old Aug 19, 2008 | 11:14 PM
rst in breaking
fiestaturbo.com says it gives a 7.4:1 compression ratio, if this is checked and correct should i have any problems with biggish boost?
Old Aug 19, 2008 | 11:26 PM
JonnyBravo's Avatar
JonnyBravo
If it was a LET I wouldn't be worried at all, can't comment on the Zetec but thats surely classed as safe
Old Aug 19, 2008 | 11:27 PM
rst in breaking
il get all the compression checked over when its apart to be sure
Old Aug 20, 2008 | 05:46 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
As above, how much boost you can run isn't just about compression ratio. Fuel, cams, spark angle etc. - all of these factors affect it.
However, 20 psi on a T34 will typically net you around 300bhp with these pistons - so unless you're planning to get a pukka head done, you won't be running 25 psi anyway. You should figure out what power you want, rather than what boost you want and then design the engine around that.
Old Aug 20, 2008 | 06:25 AM
rst in breaking
280-300bhp is the kindo of power im looking for, well i gues il just work out the compression ratio then the rest is down to davw walker
Old Aug 20, 2008 | 07:16 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You have to MEASURE it, not calculate it
Old Aug 20, 2008 | 07:35 AM
Garage19's Avatar
Garage19
I disagree!
Chamber volumes for most common heads are known and if you know how much has been skimmed off, if any, you can calculate your CR quite easily to the nearest tenth of a point. All you need is some reasonably acurate dimensions of your components.
Old Aug 20, 2008 | 07:41 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
That's fine, but I prefer to KNOW the facts.
Old Aug 20, 2008 | 09:57 AM
XRT_si's Avatar
XRT_si
I was told comp ratio is much nearer to 8.4:1 when building my old one.
As stated have to measure really.
Old Aug 20, 2008 | 10:10 AM
COZ!!!!'s Avatar
COZ!!!!
Ford -The power of dreams
i have seen some 1.6 civic turbo's running the 10:8:1 compression ratio with no probs at all. Im sure it can be done with a zetec
Old Aug 20, 2008 | 10:11 AM
Ginge !'s Avatar
Ginge !
just finding my feet
what boost and turbo though, running 7psi in a smalle turbo aint the same as running 25psi in a T34
in fact is TOTALLY different
Old Aug 20, 2008 | 03:16 PM
clarke5700's Avatar
clarke5700
but to be fair when we took your head off evon you looked confused when compairing my c20let pistons to your "c2let piston" lol
Old Aug 20, 2008 | 04:28 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
Originally Posted by Garage19
I disagree!
I'm afraid i disagree, i've measured 2 standard 2.0 zetec heads and found them to be 4cc apart, which makes quite a difference in a zetec. Measuring everything properly is the only way to know.
Old Aug 20, 2008 | 05:08 PM
crazycage's Avatar
crazycage
if you only want want 280bhp i would go well into the 9-s on your t34.
Old Aug 20, 2008 | 06:15 PM
rst in breaking
thats probally because his were different to yours and both my sets lol
Old Aug 20, 2008 | 07:43 PM
XRT_si's Avatar
XRT_si
Still made the power
And I was just stating the comp ratio of C20LET pistons, NOT what mine was
Old Aug 20, 2008 | 07:45 PM
rst in breaking
well ive read a few time its 7.4:1 but will get mine checked if anyone knows where to get it done?
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
