Replacing fuel lines on a saph, the black push fit fittings
Old 17-08-2008 | 02:50 PM
rog's Avatar
rog
Default Replacing fuel lines on a saph, the black push fit fittings
What else can you use instead of this????
It's obviousy a pain to take them apart and fir new ones as you have to prep the ends of the fuel pipe properly, so what else can you do to cross from the fuel pipe to the metal fuel line????
Old 17-08-2008 | 05:24 PM
LHD220Turbo's Avatar
LHD220Turbo
cut the platic pipes very short; about an inch from the banjo and fit 5/16" fuel line over the top and clip it
this is what i done
Old 17-08-2008 | 06:22 PM
rog's Avatar
rog
Good idea!
Old 18-08-2008 | 09:59 AM
rog's Avatar
rog
Anyone got any other "fandalged contraptions! they'd like to suggest???
Old 19-08-2008 | 12:40 PM
rog's Avatar
rog
Forgot to ask, did you do the same in the engine bay aswell???
Old 19-08-2008 | 12:45 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
I did pretty much the above, enginebay and underneath.
Old 19-08-2008 | 01:34 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
I used to do that, till I started hearin of them poppin off under serious pressure !!
I used Aeroquip & braided fuel line from pump to rail !!
jb
Old 19-08-2008 | 04:42 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Who? When?
Hydraulic equipment uses push fit and jubillee clips at HUNDREDS of psi more than a cars fuel pressure.
IIRC 2wd Cossies have the rail to fuel pressure reg pipe like that even as standard?
Old 19-08-2008 | 04:45 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
this is what i done
if you brought that into to us when we spotted it we would push your car outside and get the fire extinguishers out
Old 19-08-2008 | 04:56 PM
LHD220Turbo
surely its an improvement on the plastic type hose as standard? i found the plastic stuff split far easier
Old 19-08-2008 | 04:58 PM
Turbosystems
Super Moderator
the standard plastic fuel hose is extreme high pressure and is sweated on the special fittings,the hose will fall off and burn some fooker to death
Old 19-08-2008 | 05:00 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Originally Posted by Stavros
Who? When?
Was years ago in me Rs turbo days & that happened on a couple R 5 turbo's !!
Admittedly, they might of used crappy clips or (most probably) wrong hose or wrong size hose !! Worried me tho enought to sort it on this car !!
Yeah 2wd rail to reg is fuel hose & clipped in place BUT should be assisted by a reg bracket that bolts to the inlet. So it wouldn't "pop" off, jus leak (lot's) & drop fuel on the dizzy & catch fire !!
jb
LOL @ Tony, wait til you see mine !! (only jokin, fuel systems ok I think )
Old 19-08-2008 | 05:06 PM
LHD220Turbo
i see; the plastic is still on the banjo; i didnt pull that off. All i've done is cut it short and then fitted the hose over the top.
the hose i've used is from a hydraulic company; the chap told me the hose deals with massive psi pressures in the hydraulic industry; far in excess of what a fuel system on a car would ever see.
whats the psi at the pump and filter?
Old 19-08-2008 | 05:07 PM
rsnissan's Avatar
rsnissan
jb
you got some air freshner to get rid of the smell of optimax in back yet
Old 19-08-2008 | 05:08 PM
rsnissan's Avatar
rsnissan
the hose is not the problem its the way its attached to the the fitting i'd say
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Ford one's
Shuuuuush !! lol
jb
P.s. why you think I'm always smiling
Old 19-08-2008 | 05:29 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
I cringed when I saw that pic.
The zip ties are also a worry too, if you go over a pot hole or hump bridge and the car jolts the metal will cut the zip tie and drop your pump on the floor then the hose will fall off sparks from the cradle ignite the petrol and it will be like the film back to the future.
Been on 10 thousand miles doesn't mean its safe before I get jumped on
Old 19-08-2008 | 06:51 PM
rog's Avatar
rog
Apart from the nit picking about the way it looks.... I don't see whats wrong with hose, as the plastic one is still inside it? Its just sealed over the top with the jubilee clip. Anyway, if that's SO bad, what else can i do, as I can't go getting the original ford fittings and messing around with the end of the fuel pipes so they'll fit in those standard black plastic couplings......
Old 19-08-2008 | 06:52 PM
Turbosystems
Super Moderator
so you slid your rubber hose over some shinny smooth slippery plastic .
what you require on there is the correct hydraulic fitting for your hose
the standard regulator has a specially shaped end there is no way you can pull it off the regulator is also secured in a cradle.If you think your installation is fine you are barking mad
Old 19-08-2008 | 06:55 PM
rog's Avatar
rog
So how can you connect it to the regulator? I was thinking of doing what you said on the pump, getting a different size banjo and connecting it straight in to the hose but it still leaves the other side in the engine bay to deal with.
Old 19-08-2008 | 06:58 PM
Turbosystems
Super Moderator
we use -6 aeroquip and silver solder hydraulic fittings to the fuel rail not a jubilee clip in sight
Old 19-08-2008 | 07:00 PM
rog's Avatar
rog
Cheers, i thought as much, I take it i can send my rail of to get modified?
Old 04-09-2008 | 02:51 PM
rog's Avatar
rog
Got a ridiculous quote for some aeroquip hose so I'm forgettimng about that for the time being. I do now have a spare rail that I was going to get modified for this but no point justnow. Going to look into this further and let you know what i come up with as there must be a better solution to the problem.
Old 04-09-2008 | 02:55 PM
Jim Galbally's Avatar
Jim Galbally
i used to do the same to what rog showed, but now i've been educated
Old 04-09-2008 | 03:33 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
It's not so much the hose failing as Tony says, the probably more a case of the clips not gripping enough or failing as they have a tendancy to do !!
In all honesty, your'll probably be alright, jus remember tho, the more boost you run the more fuel pressure you get on a ratio of 1:1. Usually Cossie fuel pressure is 3.5 bar (51 psi) static (vacuum removed from reg). Which is another reason why the 2wd standard rubber hose to the reg was okay when new, only runnin 7-9 psi, with the bracket in place & decent clips.
But how many went up in smoke due to fuel leaking from there & droppin on the dizzy ?? Hence why they changed the design for the 4x4 models !!
Each to their own, if you ARE goin to use fuel hose & clips, get the clips from the same place as the hose in the correct size to allowing enough to clamp up adiquatley & also cut the complete plastic hose off, this should expose the banjo's ribbed end () give the hose & clip something to grip !!
jb
Old 17-10-2008 | 01:59 PM
rog's Avatar
rog
Ok putting this post back up, looks like I'm going to go with goodridge 200 hose I think, has anyone esle had experience with this, or another type apart from aeroquip? Also If anyone has a 4x4 that is done, i'd like to see some pics or pick your brains about some other things.
Old 17-10-2008 | 02:15 PM
rsnissan's Avatar
rsnissan
bloody hell you still doing this
if you can wait long enough i'll have my my fuel system/pump/rewire kit for sale at this rate
Old 17-10-2008 | 03:59 PM
rog's Avatar
rog
Lol yeah I am, I'm supposed to be getting some off of lamchop but I'm not entirely sure he has what I need! I have a new pump and wiring harness for a 044, been painting the underside of the car for a while and now i'm desperate to put the fuel tank and lines back on!
Old 19-10-2008 | 07:06 PM
rocky_robin's Avatar
rocky_robin
You nae got the connections yet?
It's fitted to the standard metal pipe, using a tube fitting crossed over to the funcky red fittings that you'll be getting.
Also check out the piping for the manifold. It's all off the car, so best have a looky and buy that too.
Sorted.
Old 20-10-2008 | 10:05 AM
rog's Avatar
rog
Bra!!!
No i haven't got them yet, he was busy early in the week so we've not had a chance to catch up yet. Need to get the car back in the garage asap!
Old 20-10-2008 | 10:35 AM
dojj's Avatar
dojj
Resident Wrestling Legend
think of it this way, if you pay high prices for the best hose you can get, you won't ever have to replace it AND you will have the benifit of being able to quickly undo it should you need to change something
the plastic way would be ok for a n/a car with a doubled up jubiliee clip either side as a temprary mesure but i'd still take the time and effort to do it corretly rather than have soemthing that "I'll fix when i can get round to it"
i think i can safely say that i've sat in the garden watching my cossie going up in flames due to the fuel burning the car running around like a headless chicken with the hose pipe out trying to put the fire out, it's not nice
Gaz 88
Ford Focus RS Parts for Sale.
29
10-05-2017 12:31 PM
3doorcozmess
21-08-2015 11:17 AM
ar4ibaldo
Ford Focus ST
18-08-2015 04:24 PM
RSMK4TURBO
13-08-2015 08:06 AM
muffster
12-08-2015 08:14 PM
Quick Reply: Replacing fuel lines on a saph, the black push fit fittings
