another quick gearbox mount question.....
Old Aug 11, 2008 | 07:30 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
Default another quick gearbox mount question.....
im having trouble determining the gearbox mount used in my cossie converted bmw.the rubber has perished. is the 3 door gearbox mount the same as the 2wd saph gearbox mount? is there an online parts etk similar to bmw showing outline drawings and part numbers as used by ford?
Old Aug 15, 2008 | 08:58 PM
fuzzy's Avatar
fuzzy
hello...hello.... is there anybody out there.....?
Old Aug 16, 2008 | 07:39 AM
3 door is pressed steel, sapphy(2wd) is cast alloy, same fitment etc though.
Old Aug 16, 2008 | 09:56 AM
fuzzy's Avatar
fuzzy
thanks , it seems like it could be the 3 door steel cradle then with bmw ends welded on. its definately not an alloy cradle. its the centre rubber bush within a steel frame that riveted to the main cradle thats perished. would you happen to know if thats a ford main dealer part thats still available?
Old Aug 16, 2008 | 05:32 PM
I bought one late last year/early this year so should be ok.
Old Aug 16, 2008 | 06:52 PM
abdr500's Avatar
abdr500
i have a ford 909 3 door gear box mount for sale pm me if you want
Old Aug 16, 2008 | 06:53 PM
fuzzy's Avatar
fuzzy
one last question. how much from ford?
Old Aug 16, 2008 | 06:54 PM
fuzzy's Avatar
fuzzy
whats a 909 mount?
Old Aug 16, 2008 | 07:03 PM
909 is ford motorsport, anything that has a part number beggining with 909.
The std one I bought from memory was about £20-£25.
Old Aug 16, 2008 | 09:12 PM
fuzzy's Avatar
fuzzy
i remember reading that the uprated motorsport mounts werent recommended for road use as they are to harsh. is that true? bearing in mind its for my fully loaded everyday use comfy bmw estate
Old Aug 17, 2008 | 06:23 AM
I was in a cossie with a solid gearbox mount, and all I noticed was a tinny sort of buzz at low revs, just thought the exhaust was touching somewhere.
It was so slight I forgot about it after 10 mins or so.
TPM961
Jan 15, 2018 10:50 AM
yatta
May 21, 2016 10:31 PM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
155lee
Oct 27, 2015 04:55 AM
