Bhp Figure????!!!
#41
And i suppose u run with valve cut outs
Good power for the spec
Paul
#42
What base fuel pressure and injector duty are you running? One or both of them must be quite high?
555cc @ 3bar @ 85% @ 0.5BSFC = 359bhp
555cc @ 3bar @ 100% @ 0.5BSFC = 422bhp
#45
Jap cars tend to limit injectors to about 80ish% duty (so I'd have thought Norris might stick to that) as above that increases failure rate (allegedly). So the base pressure must be quite high? What pressure do cossies normally run?
#48
#50
Its got standard rods i'd like to see someone break one they are as strong as f*&%$ lol
#53
its 4 wheel drive Standard box and diffs alcon six paddle spent lots of money on engine and car probably quaife the box next year when i have recovered financially if it breaks one in the meantime ive got a spare
#55
#56
Well you have got to push on a bit dont you, have none of you any spine lol I will take you out in cossie when its done should punt along a bit i reckon and its got 4 wd so its going to be a laugh without going sideways
#57
LOL sideways i know all about that 330 bhp cortina = fast and sideways
FWD is for Girls eh Spence
Paul
#58
#59
is it omex 600 you run?
#60
#61
what you hannt allowed for in your calculation is that at 2 bar boost, fuel pressure will rise by an equal amount so fuel pressure at 2 bar will be 5.5 bar
#62
Fuck that. Utter peices of shit, don't bother. Go for a bara/ mullit box instead, much better
#64
Fuel pressure will be 5.5bar that's true, but the pressure difference over the injector will be 3.5bar since there is 2bar pressure in the inlet manifold, so the pressure injector is working, is the same 3.5bar all the time.
#65
whats the difference between a wrc block and the standard 200 block?
how many long studs is it just the 6 or the full 10?
i've got a small turbo escort that already has oil spray jets installed does it not? been thinkin about ditchin the ford eevc 4 an goin after market managment
#66
well fuck me with a barge pole you have finally got it done !!!!!!!!!!!!!!!!!!!!!!
hi there big boy im back from hols
so is it up for sale now then ????????????????????????????/
have you missed me ?????????????
i here there has been some fun and games on here while i have been away
#67
