Sierra hubs ???????????
Wot is the difference between 3dr and sapphire front hubs.Apart from one needs pinch bolt type track control arms and the other doesn't.Is 1 better for handling and why.As i'm sure i've heard this somewhere before.??????
Team HOTHOT!
all 2wd ones (wether it be mk1 or mk2, 3 door, 5 door, sapphire, estate) are the same and use a catle nut to holt the bottom ball joint into the hub
4x4 tca's use a pinch bolt to hold the bottom ball joint into the hub.
3dr ones are better.
According to one of my sources , the TCA attaches at the top facing down, which means that when the front of the car is lowered, the TCA has less angle, and aids turn in.
Team HOTHOT!
oooooops my bad, same style of fitting for the bottom ball joint i meant to put above,
2wd hubs do vary in offsets from each type of sierra, same goes for 4wd ones aswell
This is what i was also led to believe
Team HOTHOT!
i know for a fact that all 4wd ones have a pinch bolt and all the 2wd sierras i've seen have a castle nut - might be the 2wd cossie ones that have a pinch bolt too?
chowfornow
14
05-01-2019 09:01 PM
