F.A.O any electronics peeps
my car alarm at the mo has 1 led on it, the new dash i am gonna be puttin in has 2 already in it
questions.............. how much voltage does a led use ie if 2 are wired ip from the one set of wire comin from the alarm will it pick up a voltage drop ?
what would happen if i wired the 2 wires up the wrong way round on the led would it burn it out etc ?
and i presume connecting the led's to the alarm wire is just a case of soldering them on ?
hope you can help..........matt
PassionBMW.com Member
Mate, the voltage drop by using two LEDs will be fuck all and wont cause you any problems.
The only thing youll have to do is wire them up together (series or parralel) by remember as they are diodes, they will noly work if the polarity is the correct way round, so if they dont light up, turn them round
Hope this helps.
Hope this helps.
Originally Posted by slowpoke
ok thanks guys is soldering the best way to connect the wires ?
didnt think of crimping
thanks for your help guys thats a job for tommorow
how long ya reckon it will take to swap a upper dash over on a saph ?
matt
matt
